| System Setup and Connection Need help with my pro audio stuffDiscuss Need help with my pro audio stuff in the Home Theater | Audio and Video forum; Need help with my pro audio stuff Okay I will be using quite a bit of pro audio components in my hometheater. I will be using the ... |
| | #1 (Link) | |||
| Need help with my pro audio stuff Okay I will be using quite a bit of pro audio components in my hometheater. I will be using the Behringer DCX 2496 and the DEQ 2496. I have the panasonic xr57 reciever feeding a Behringer ep1500 and ep2500. I have to use clean boxes to get it up to pro line feed voltage. What I need is an understanding of where in the flow of the chain these behringer components would go. Do I go receiver to cleanbox to dcx to deq to speakers? If you need more info let me know? thanks. | |||
| | #2 (Link) | ||||
| | Re: Need help with my pro audio stuff Quote:
Basically, whatever you’re using to boost the signal should be after the receiver and in front of the pro gear.Not sure how necessary this, however. The gear can operate at consumer signal levels. As long as there is sufficient signal to drive the amplifiers to maximum output, you’re fine. In addition, the DCX has gain controls for the input signal after the ACD converters. This would probably be a better way of boosting signal, if it needs to be. Regards, Wayne | ||||
| | #4 (Link) | |||
| Re: Need help with my pro audio stuff Thanks Wayne I was cross posting with you. I found I have to use the clean box with my IB setup so I ordered an extra one with the processors. So to confrm receiver to clean box to amp to dcx to deq to speakers.This layout gives me the most flexibilitly. | |||
| | #5 (Link) | |||
| | Re: Need help with my pro audio stuff Oh, didn’t know about the IB. In that case, you might want to consult with the folks at our DIY Subwoofer Forum. Still, the DCX has input gain controls that the Behringer digital EQs don’t, and it’ll digitally boost the incoming signal up to 15 dB. I’ll really be surprised if you need the clean box once you put the DCX in the system. Regards, Wayne | |||
| | #6 (Link) | |||
| Re: Need help with my pro audio stuff I'll second this. Also, putting more stuff in your signal path is not always a good idea, unless it's really needed. "Until mankind is peaceful enough not to have violence on the news, there's no point in taking it out of shows that need it for entertainment value." - Clueless The imperative is to make a subjective study an objective fact. | |||
| | #7 (Link) | |||||
You have a 7.1 channel receiver that employs its own bass management and has its own internal power amplifiers. Presumably, your 7 speakers (that the receiver would normally drive) use their own internal crossovers. You are purchasing a (3 input/6 output) loudspeaker management system (DCX) and a (2 channel) parametric equalizer with EQ (DEQ). What are you proposing and why? ![]() brucek | |||||
| | #9 (Link) | |||
| Re: Need help with my pro audio stuff Yeah I a guillty of not putting out enough info. I was trying to keep it simple but here goes. I have built a 4ohm wmtw CC and it is a hoss. On top of that I am building some Natalie Ps for mains with seperate bass bins. These are also 4ohms. All of these speakers will handle much more than my pany xr57 which does have pre outs. I have 2 ascendant audio 15" subs that will have a 1/2 a behringer ep2500 powering them. The other 1/2 will power the CC. My current ep1500 will power the Nat Ps. So in short my whole front including subs are much higher wattage than my pany can produce and at a 4om load. Now in the future I will get another ep 1500 for the bass bins. I said earlier that the whole front end was 4 ohm but at first the bass bins will be 8 ohm and the pany having the ability to take 2 of the surround channels and use them for bi amping the front mains will temporarily fill this need. Later I will put a couple more drivers in the bass bins causing them to go 4ohm and needing more wattage. Also in the future I want to be able to add 2 mach 5 audio 18.4 subs to the IB. When that happens I will move the ep 2500 to just IB use and get a behringer a 500 for the center channel. So this is why I feel I need the extra processing. I hope I have made myself clear. I have to keep stuff written down and diagrammed on this set up or I get turned around thinking about it Also please realise that I am adding this stuff as I go and this has been part of a 4 year home theater project that began with me building the dedicated room. Along the way I have had to take on a lot of desciplins that I am totally unfamiliar with. Where is the spell check. Audio theory and acoustics being at the very top of the heap. Audio is the latest one I am getting into and acoustics have pretty much been decided on but will not be finalized till the system is up and running. Sorry for the long reply but I thought it needfull to make it all clear. I hope I have not muddied the waters with to much info. Thanks all for looking. | |||
| | #11 (Link) | |||
| Re: Need help with my pro audio stuff Sorry but I felt I needed to add this. The pannies mains lowest crossover point is 100hz. The biamping setup with using the surround channels actually seperates the surrounds amp as the lower part of the mains signal. Where it crosses over on the top end is not stated. With the bass bins I want to do something like 60 to 80hz and top them off around 250hz. Thus the need for extra processing because all my speakers will be set to large to do this to accomplish this. I hope once again I have made myself clear. Thanks again for reading and any help would be greatly appreciated. | |||
| | #12 (Link) | ||||
One of the things that would concern me is operating the DCX in analog mode combined with a DEQ. I'm sure you know that the two devices may contribute to some floor level hiss that you might find objectionable. You're creating quite a complex system...... brucek | ||||
| | #13 (Link) | |||
| Re: Need help with my pro audio stuff Well to tell you the truth bru I love this little digital amp. The only problem is the lack of bells and whistles. Please don't take this wrong but I work as an operator of some pretty complicated systems and I have found complicated is often just a bunch of simple systems that are ganged together. I love to tinker so this is right up my alley. When it is all said and done I will need to put some automation in with the pro stuff and get something like a harmony remote with macros to make it work for the rest of my crew. Cheers and have a great day. | |||
| | #14 (Link) | |||||
| | Re: Need help with my pro audio stuff Okay – I get it, you’re using the DCX as an outboard processor for the Natalies / bass bins combo. Quote:
http://media.onecall.com/Image_Produ...nic/SAXR57.pdf Like brucek, I’m wondering where the DEQ fits into the picture, because the DCX has built-in equalization. The manual doesn’t say how many filters are available, except that using less processing power will make more filters available. Seeing as you probably won’t be using many of the DCX’s features, such as the compressors and dynamic EQ, you might have at least a few filters available, possible more. EQing the mains, that would be enough, so you wouldn’t need the DEQ. ’Course, if you’re dedicating the DEQ to the subs, that’s a different story... Quote:
Regards, Wayne | |||||
| | #15 (Link) | |||
| Re: Need help with my pro audio stuff Hey Wayne you had me going so I looked once again on the back end of my panny and the preouts are there big guy. It is set up for only 5.1 instead of the 7.1. There are actually two sub woofer connections. I just got off a 12 hour shift so I will look up which one does what when I get back up. I had actually forgotten the second one. Cheers | |||
| | #16 (Link) | ||||
Anyway, my point was that a DCX and DEQ combo will digitize and undigitize the signal many times and pass through quite a few analog line amps, and may disturb the original pristine signal. brucek | ||||
| | #18 (Link) | |||
| Re: Need help with my pro audio stuff Wll being a lot more concious now than yesterday morning I looked once again at what I thought where preouts. They are not. Wayne was correct. Oh boy has my world just changed. I need some recommendations for either an reciever that does serious 4 ohm load with 7.1 or a 7.1 that has at least 5.1 preouts. Need to keep price to less than $1000. Thanks in advance. Now where is that " I hate to be wrong head bashing post I have around here". You guys have a great day. | |||
| | #19 (Link) | |||
| | Re: Need help with my pro audio stuff Yeah, I thought those multi-channel inputs might have been the problem – i.e., mistaking them for outputs. Don’t know about 4-ohm receivers (you might want to open a new thread in the appropriate Forum), but just about any receiver these days has 5.1 outputs. Sorry yours isn’t one of them! ![]() Regards, Wayne | |||
| | #20 (Link) | ||||
brucek | ||||
