Hi,
I have owned a Samsung surround sound system with wireless rear speakers (model HT Z520) for a couple of years. There is a problem that I have tried to ignore but have come to a point where I am considering getting rid of the unit altogether.
I have a large den where the wireless speakers were a huge part of buying the system (too hard to run wired cables). The unit is linked to a Samsung TV through the "Aux 2' port not "Anynet". When the system is turned on and the volume goes up above 6 or 7, there is a buzzing that comes out of the rear amp (the two wireless speakers are linke to this rear amp). I have tried to adjust the surround sound features without success. A couple of calls to Samsung have not helped (they said it was the fan, but I don't believe it is as the buzzing stops and starts at a certain volume level).
Does anyone have any thoughts/suggestions to try. I'm sure there may be some simple reset or configuration that I have missed. My disclaimer; I am pretty tech naive. many thanks,
Ali Y
Ali Y
