Need help setting up amp and crossover to receiver - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Need help setting up amp and crossover to receiver in the Home Theater | Audio and Video forum; Need help setting up amp and crossover to receiver I have received both the amp and the crossover and they look so sexy together. But now I have to ...
Old 10-11-07, 12:04 PM   #1 (Link)
Alias: Daniel Wang
User: #11134
Since: Aug 2007
drwang84 is offline
I have received both the amp and the crossover and they look so sexy together. But now I have to hook them up and I'm not sure where to start.
Marantz 2385 receiver --> Behringer CX2310 --> Behringer EP2500 -->subwoofer
Please correct me if I'm wrong: From the receiver Pre-out I connect an audio rca cable to the crossover.(Here's the problem, the crossover only takes XLR, right? From the crossover to the amp I need (1) XLR cable for mono sub. And from the amp to the subwoofer, the speaker wire can be connected to the binding posts behind the plastic covers. And from the subwoofer, how do I connect back to the Main-in?
I tried reading all the manuals together and some of the jargon is a tad confusing. Thanks for taking the time to help me out guys.
So all-in-all I think I need to purchase (2) XLR cables and perhaps something that converts the RCA audio cable to XLR.
Old 10-11-07, 01:59 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Need help setting up amp and crossover to receiver
Not sure how you arrived at needing only two cables, since this receiver doesn’t have a mono subwoofer output. You’re going to need to use both channel pre-outs from the Marantz, to both inputs on the crossover, and then a single cable from the crossover’s mono sub out to the EP2500, assuming you intend to bridge it.
For that you need another pair of cables, to send from the crossover’s high output back to the Marantz’s main ins.
This will insert the crossover in the signal chain of the main speakers, but I’m not sure its sonics are up to the quality of Marantz’s (which are about as good as things get).
You could use some 2-male to single female RCA splitters across the pre-outs and main-ins, which would give you a “tap” for the crossover while keeping it out of the main signal chain. However, this would mean no high pass for the main speakers.
Old 10-12-07, 12:11 AM   #3 (Link)
Alias: Daniel Wang
User: #11134
Since: Aug 2007
drwang84 is offline
Wow,
Thanks for the reply. Just to recap, I need:
(2)XLR to RCA
(2)2-male to single female RCA splitter
(2)2 XLR male to male
I was just searching google for a place to buy XLR cables and they average around $25 a piece! This might add up to $100 easily,..ouch!
If this is all that I need, I will order very soon.
Old 10-12-07, 12:31 AM   #4 (Link)
Alias: Daniel Wang
User: #11134
Since: Aug 2007
drwang84 is offline
Also, how important is the quality of the XLR cables because I saw a craigslist post for a Box of cables (7 XLR) and plenty of mic clips(including stereo pair mounting bracket) $30.
Old 10-12-07, 09:30 AM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
drwang84 wrote: View Post
(2)XLR to RCA
XLR male to female. That’s for between the crossover’s low output to the EP2500. If you’re running the EP bridged mono, then you’ll only need one cable from the crossover.
Typically what they’re selling you is “mic cables,” which are usually 12 ft. or longer. I doubt you need anything that long. Poke around the recording studio section of a store or on-line vendor; that’s your best bet to find something shorter (and hopefully cheaper) that’s intended for an equipment rack.
The main problem with cheap XLR cables is that they don’t hold up well when used on a stage, where they get handled all the time, jerked around, stepped on, etc. In a static home installation, where none of that applies, they’ll do fine.
Old 10-12-07, 12:58 PM   #6 (Link)
Alias: Daniel Wang
User: #11134
Since: Aug 2007
drwang84 is offline
THANKS WAYNE!
I will get the equipment soon. I really appreciate the help. So I'll get the male to female XLR connectors instead then.
Old 10-14-07, 01:05 AM   #7 (Link)
Alias: Daniel Wang
User: #11134
Since: Aug 2007
drwang84 is offline
I got the XLR cables and now I need to convert from the RCA to XLR. Am I supposed to use a ART CleanBox or can I just get RCA Male to XLR Male Adapters?
http://cgi.ebay.com/6-RCA-Male-to-XL...QQcmdZViewItem
http://cgi.ebay.com/NEW-ART-CleanBox...QQcmdZViewItem
Old 10-14-07, 03:41 PM   #8 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Why not just get some XLR to RCA cables? After you plug your cables into the adapter, you’re going to have 4-5 inches sticking out of the back of your receiver. All that weight can’t be good for the jack on the receiver.
No reason to get a clean box until you determine you need one.
Old 10-14-07, 11:08 PM   #9 (Link)
Alias: Daniel Wang
User: #11134
Since: Aug 2007
drwang84 is offline
That makes sense. Good idea. Firstly I need to figure out if I need the male XLR or female XLR cables to rca. I will check the connections after work tomorrow. Thanks.
Old 10-19-07, 05:29 PM   #10 (Link)
Alias: Daniel Wang
User: #11134
Since: Aug 2007
drwang84 is offline
Hi Wayne,
I'm back for more help, yet again. I connected everything today after work and I just realized that you mentioned I need two xlr to rca cables for the main in and another 2 for the preouts. As you may have already guessed, I only bought one of each.
However, I did hook it up and the subwoofer didn't play anything. I should still be able to get some bass even though it's only hooked up to one of the channels right?
I'm going to order the extra cables right now. Looking forward to your reply Wayne.
Old 10-19-07, 08:07 PM   #11 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Well, you have quite a few pieces in your signal chain now, and you’re probably not familiar with how to operate a lot of it, since you’re new to pro gear. So go back and check the basics. I’d especially pay attention to the crossover and make sure you have it connected correctly, gain settings adjusted, proper switches engaged, etc. (remember, it can be set for stereo two-way or mono three-way). Plus, I don’t think you ever confirmed if you’re bridging the amp or not. There are settings and connections there that you have to pay attention to as well.
Old 10-31-07, 08:02 PM   #12 (Link)
Alias: Daniel Wang
User: #11134
Since: Aug 2007
drwang84 is offline
Hey Wayne,
I finally got the subwoofer to play!! =) Thank you so much. But once again I've run into another issue, ... surprise, surprise...
Right now it's working fine with just one of the 2 speakers playing + sub. However as soon as I add the Y-adapter 2 male rca to 1 female rca then only the subwoofer plays and neither speaker works.
This was what you originally suggested:
"You could use some 2-male to single female RCA splitters across the pre-outs and main-ins, which would give you a “tap” for the crossover while keeping it out of the main signal chain. However, this would mean no high pass for the main speakers."
I plugged the y adapter from right+left preout to crossover xlr and then crossover xlr to the y adapter right+left.
Perhaps I'm missing something here?
PS. Happy Halloween!
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
FS: 50" Samsung 1080P DLP & DVD upconvert/receiver with 5.1 surround system LG-HTI E-A-G-L-E-S Classifieds - Video Displays and Projectors 2 09-18-07 06:32 PM
Yamaha RX-V1700 Receiver / RX-V2700 Receiver - Official Owners Thread Sonnie Home Theater Components 88 09-18-07 10:41 AM
Equalizer & Accurian 5.1 Home Theater Receiver jimlp1 System Setup and Connection 2 06-15-07 11:11 PM
I need help setting the crossover in my new receiver johnwestcoast Home Audio Speakers 3 03-25-07 10:13 PM
Pre/pro + Amp or all-in-on receiver? haver Home Theater Components 21 07-17-06 11:30 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168
