How to setup Bose Acoustimass 6 speakers to Pioneer vsx-822k receiver - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 6 Old 07-22-13, 02:21 PM Thread Starter
I recently bought "Acoustimassģ 5.1 speaker system with Pioneer VSX-822K receiver" from Costco. My house has surround sound pre-wiring. I am not sure how to connect acoustimass sub-woofer to the pioneer receiver.
Sub-woofer connection is in the back of the room. I opened the wallplate and it has one thick black wire (haven't stripped it yet to see what color wires are there in that). I am assuming that I can use an RCA / co-axial connector to connect it to my sub-woofer. But the bose sub-woofer has multi pin audio input jack. How do I connect the pre-wire that I have in my house to the sub woofer?
Also, the manual shows that I need to connect the speakers and the receiver to the sub-woofer. But I was thinking that I need to connect both speakers and sub-woofer to the receiver. I found in some other forum that, usually it is the case of sub-woofer and speakers connecting to receiver, but in case of base it is other way. Is it true?
I am a total newbie and any help is really appreciated.
rememberme is offline
post #2 of 6 Old 07-22-13, 02:28 PM
tonyvdb's Avatar
Tony
Re: How to setup Bose Acoustimass 6 speakers to Pioneer vsx-822k receiver
Hello and welcome aboard the HTS.
Have you read this post here? that should get you going.
Home theater:
Living room system:
tonyvdb is offline
post #3 of 6 Old 07-22-13, 02:35 PM Thread Starter
Yes, I did. Before I bought this speaker and receiver system. I was aware of how the connections will be. But when I saw multi pin audio input jack on the back of base woofer, I searched online if there is an adapter for RCA to multipin audio jack and I didn't find any. So thought of asking here, if anyone has similar system and if so how was it setup. If I had to connect subwoofer directly to receiver, then i won't have any issues, but I want to use the pre-wiring and how sure how to connect that pre-wiring to subwoofer (multipin audio jack)
post #4 of 6 Old 07-22-13, 04:40 PM
Mike P.'s Avatar
Mike
If you want to use the prewiring for the subwoofer that is located at the back of the room then the prewire needs to be a RCA connection that will connect to the RCA input on the back of the subwoofer. You mentioned the prewire cable was a thick black cable, I'm assuming this is a coax cable that will need a RCA end installed.
We're all in this together!
Mike P. is offline
post #5 of 6 Old 07-23-13, 09:22 AM Thread Starter
Mike,
Thanks for the reply. But back of my Bose sub woofer doesn't have an RCA input/output. Instead it has a multipin audio input.
Refer to attachment of how the connection was given in the bose manual. With my existing pre-wiring, I am not sure if I can use this. I have to either connect as shown in the image and ignore my pre-wiring OR change the system. Correct me if I am wrong and if there are any other options.
How to setup Bose Acoustimass 6 speakers to Pioneer vsx-822k receiver-bose.jpg
post #6 of 6 Old 07-31-13, 07:16 PM
RTS100x5's Avatar
RTS100x5
Yes just splice an RCA cable to the subwoofer wire....its tedious but not too difficult...
or try RADIO SHACK or MONOPRICE.com for an item like this
http://compare.ebay.com/like/3606281...Types&var=sbar
AVR - PIONEER SC 35 w PANGEA AC9 CORD
AC FILT - PANAMAX M5400
DISPLAY - PANASONIC TC-P54G10 54in 1080p PLASMA
MAINS + SURROUND - DIY w DAYTON PT2C-8 PLANAR MID/HIGHS + DAYTON 6.5 MIDBASS -
SUBS - (2) DAYTON 15" ULTIMAX
SUB AMP - ACURUS A250
HTPC - WIN7 ULT,INTEL I7 860,CORSAIR 800D,CORSAIR HX1000, 16 GIG CORSAIR,EVGA P55 MB, ATI 5970 VIDEO, ASUS HDAV DELUXE 1.3 w BURSON DISCREET OPAMPS,PIONEER BDRW, 3WARE 9650 w 4x CRUCIAL 64gb SSD's in RAID 0
RTS100x5 is offline
acoustimass , bose , pioneer , receiver , setup , speakers , vsx822k
