| System Setup and Connection Onkyo 805 hmdi to Mitsubishi WD65734 ProblemDiscuss Onkyo 805 hmdi to Mitsubishi WD65734 Problem in the Home Theater | Audio and Video forum; Onkyo 805 hmdi to Mitsubishi WD65734 Problem Hello all,
I have a TXSR-805 hooked up to a Mitsubishi WD65734 with a HMDI cable. The TV does not ... |
| | #1 (Link) | |||
| Hello all, I have a TXSR-805 hooked up to a Mitsubishi WD65734 with a HMDI cable. The TV does not auto sense the HMDI from the recever. I have to go to the menu and put the input to a HMDI source and then plug the cable into that source on the TV every time to get it to work. When I turn it off and start it all back up, the TV does not show any HMDI cables pluged in. I tried going direct from my DVD to the TV and it works fine. Same with the DISH box. I would like to use the 805 to switch it all for me if I can. Any ideas out there? | |||
| | #3 (Link) | |||
| Re: Onkyo 805 hmdi to Mitsubishi WD65734 Problem Yep, I'm sure. It all works when I plug it in the HDMI port on the tv the first time. I get the 805 menu and anything else I select. On the 805 menu I have monotor out set to HDMI. | |||
| | #4 (Link) | |||
| Re: Onkyo 805 hmdi to Mitsubishi WD65734 Problem Try different combinations of startup sequence. "It is better to debate a question without settling it than to settle a question without debating it." -Joseph Joubert Raise the bar. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Mitsubishi WS-55511 Problem | falcon935 | Manufacturers Service and Support | 20 | 05-21-08 11:50 AM |
| Onkyo 805 or equivalent Denon? | tonyvdb | Home Theater Components | 4 | 11-08-07 11:35 PM |
| Anyone use REW to measure Onkyo 805? | lovingdvd | Home Theater Components | 12 | 10-18-07 01:17 AM |
| problem with Mitsubishi ws-65819 | cpojoe | Manufacturers Service and Support | 4 | 07-27-07 11:40 PM |
| problem with Mitsubishi WS-55819 | stef757 | Manufacturers Service and Support | 2 | 02-04-07 03:24 AM |
