Best Speaker Placement? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss Best Speaker Placement? in the Home Theater | Audio and Video forum; Best Speaker Placement? Hi everyone, Im new to home theatre systems. I recently bought a HTiB, the Yamaha YHT-585BL to be exact. I ...
Old 02-05-08, 08:44 AM   #1 (Link)
New Member
Alias: Mark
User: #16479
Since: Feb 2008
mfk5331 is offline
Hi everyone, Im new to home theatre systems. I recently bought a HTiB, the Yamaha YHT-585BL to be exact. I have it set up with the surround speakers in a temporary position. I want to mount them on the wall, but Im not sure where the best spot would be to mount them.
I have attached a quick, rough sketch of how my living room is set up. I basically want to mount the rear speakers somewhere that they will sound best no matter where Im sitting. I know the ideal setup is to have the speakers mounted so you sit directly in the center, but thats not possible in my situation. Basically Im looking for some advice from you experts on where to mount the rear speakers to get the best sound.
Thanks.
By the way, the center speaker is under the TV on the TV stand, not in front of the TV like the picture shows.
Old 02-05-08, 09:38 AM   #2 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Re: Best Speaker Placement?
well your room layout is defiantly not ideal but in your case I would put the one rear speaker next to the opening in the corner at the rear of the room and the other one along the long wall near the back as well. Mount them up just above head hight and toe-in slightly.
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2 HD DVD & Samsung BDP1400 BluRay players, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
Old 02-05-08, 09:42 AM   #3 (Link)
Shack Objectivist
Alias: Andrew
Loc: Ames, IA
avaserfi's Avatar
User: #9992
Since: Jul 2007
avaserfi is online now
tonyvdb wrote: View Post
Welcome to the Shack!
I agree with this suggestion. Due to your seating positions it will be hard to get every seat to sound perfect, but this compromise will give everyone a good experience.
-Andrew
Old 02-05-08, 05:23 PM   #4 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
I agree with Tony and Andrew ... after you install the speakers, run YPAO (auto calibration) and let the receiver adjust the speaker levels, if possible manually adjust anything to your personal taste (most of the time you need to change the speaker distance, size small instead of large and subwoofer crossover).
Oh ... Welcome to the forum
Old 02-05-08, 05:57 PM   #5 (Link)
New Member
Alias: Mark
User: #16479
Since: Feb 2008
mfk5331 is offline
Thanks for all the help. Before I start drilling holes in the wall, I just wanted to clarify where exactly your talking about. Im pretty sure I know where your talking about. I marked the picture with the dark blue X where I think your talking about.
Again, thank you for the help. I really appreciate your advice.
Old 02-05-08, 06:40 PM   #6 (Link)
Alias: David
Loc: Fontana, CA
salvasol's Avatar
User: #3627
Since: Oct 2006
salvasol is offline
mfk5331 wrote: View Post
Thanks for all the help. Before I start drilling holes in the wall, I just wanted to clarify where exactly your talking about. Im pretty sure I know where your talking about. I marked the picture with the dark blue X where I think your talking about...
I was thinking one on the middle of the wall between kitchen and master (unless is a half wall) and the other on the middle of the long wall ...
Is there any way you can change the placement of seats, TV, etc.???? ... I was thinking moving the TV to the narrow wall near the bedroom doors .... ... you can position the sofa in front of the TV (this will be your main seat) and the love seat against the main door wall ... but I don't know if you have windows there (I'm sure you do) ... if you move the seats, the surrounds can be placed against each long wall ... another option is, leave it the way you have it now, and use stands to place the speakers, one behind each sofa
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
Speaker placement for 7.1 system tonyvdb Home Audio Speakers 7 11-20-07 11:29 AM
Speaker placement question Instal Home Audio Speakers 6 10-26-07 11:58 AM
Surround speaker placement? Dbeistel Home Audio Speakers 5 10-19-07 06:15 AM
Speaker Placement Strategies? geekwithfamily HiFi Audio Components 11 06-07-07 10:57 AM
Rear Speaker Placement Tommy Home Audio Speakers 20 07-31-06 07:12 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
