HELP with Kenwood Spectrum 871 (KC-993) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > System Setup and Connection
Discuss HELP with Kenwood Spectrum 871 (KC-993) in the Home Theater | Audio and Video forum; HELP with Kenwood Spectrum 871 (KC-993) I have this home stereo and a few years ago the volume knob on the amplifier quit working. No matter ...
Old 03-12-08, 02:20 PM   #1 (Link)
New Member
Alias: Espi3030
Loc: Montgomery, AL
User: #18081
Since: Mar 2008
espi3030 is offline
I have this home stereo and a few years ago the volume knob on the amplifier quit working. No matter which way I turn it, the volume shoots way up instantly, very annoying. Does anyone know of a possible solution, a do it yourself type fix? Thank you in advance.
Old 03-12-08, 03:07 PM   #2 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is online now
Re: HELP with Kenwood Spectrum 871 (KC-993)
Have you tried not sitting on the remote??
No seriously, I had this same problem a year ago. After trouble shooting for an hour, I found the remote wedged between two couch cushions, with the volume up continually depressed. To that end, in case it's you remote just plain malfunctioning, try covering the IR sensor on the unit, or moving the remote to another room.
If that's not the problem, you're looking at an in-shop fix, I'm afraid.
Old 03-12-08, 03:16 PM   #3 (Link)
New Member
Alias: Espi3030
Loc: Montgomery, AL
User: #18081
Since: Mar 2008
espi3030 is offline
Thanks for the reply, unfortunately the remote cannot possibly be the issue. I lost the remote during a move, about 5 years ago (and have moved 3 time since then). Then a friend of mine had the stereo for a couple of years and he had the same issue, now that I have it back the problem still persists. I just hope someone out there has fixed this problem and can help me as well.
Thank you.
« Home Theater Shack > Home Theater | Audio and Video > System Setup and Connection »
Similar Threads
Spectrum/RTA feature nick72 REW Forum 16 08-30-08 12:25 PM
Spectrum Images mechman Projector Screens | DIY Screens 9 03-07-08 07:21 AM
Kenwood lcaillo Manufacturer and Vendor Reference Information 0 05-14-07 07:36 AM
Kenwood Home Theatre System Help Required !!! unstopabl3 System Setup and Connection 17 03-24-07 09:58 AM
Bass Effects on Downmixing DD to Stereo and Spectrum Labs information Ilkka Home Audio Subwoofers 101 01-24-07 09:27 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
