Stereo imaging/soundstage question - Home Theater Forum and Systems - HomeTheaterShack.com
 3Likes
post #1 of 19 Old 08-10-16, 09:59 AM Thread Starter
Ken
Greetings!
I'm curious about a stereo effect that I've been able to hear on some speakers but not others, and I would like to know how many folks on the forum have a system that will duplicate the effect.
On the I Ching track "Young Girl's Heart" (Chesky Records), there's an announcement over PA speakers in the intro that's recorded out of phase. On my previous speakers (and even my very cheap Dayton Audio bookshelf speakers), it sounds like the announcement is playing right in my ear, like I'm wearing headphones. There is no mistaking the effect; when I demo'd this track for people on my previous system they would have a very strong reaction to the sensation. On my newer system, the same PA announcement is projected into the room and diffuse sounding, but it doesn't sound like it's right in my ear.
With my previous system, there are similar effects on other tracks that would actually sound like they were behind me, but my newer system will only portray the sounds as off to the sides at best. My new system has better separation of instruments, detail & resolution, a very strong center image, and stereo soundstage the extends beyond the width of the speakers... but the out of phase effects are not as pronounced.
Is this 'headphone effect' a sign of something the speaker is doing right, or is it a sign of something wrong? If it's the correct- or desired- response form the speaker, are there any setup tips to duplicate it?
bugal1998 is offline
post #2 of 19 Old 08-10-16, 11:30 AM
tonyvdb's Avatar
Tony
Re: Stereo imaging/soundstage question
Speaker placement is the key here. Even toe in of the speakers can change how they sound to the listener. Speakers should never be place to close to a corner and should be out into the room some distance (depending on the design). The tweeter should be at ear level and aimed at the listening position to get the best results.
Home theater:
Living room system:
tonyvdb is offline
post #3 of 19 Old 08-10-16, 09:06 PM Thread Starter
Ken
Thanks, Tony.
I've been diligent about symetry of toe-in and placement, and I've tried many combinations. I've added acoustic panels at the side-wall first reflection points, behind the speakers, front-wall first reflection, and behind the listening position.
If producing this 'headphone effect' is a sign of a well performing speaker, then I'm beginning to think it may be a fundamental deficiency in the speakers.
post #4 of 19 Old 08-11-16, 10:33 AM
Dwight Angus's Avatar
Dwight
Have you tried adjusting your MLP? I noticed a huge improvement by moving my mlp closer to 38% of room length.
Mains- Goldenear Triton One's
Center Channel- Goldenear Super Centre XL
Surrounds- Goldenear SuperSat 50's
Back Surrounds- Goldenear SuperSat 50c's
Atmos -Goldenear HTR 7000's
Amps- Bryston 4Bsst2/Emotiva XPA-5/Marantz M7025
Processor-Marantz AV7703 Preamp
Projector- Sony VPL-HW55ES
Screen- Elunevision 140 inch 4K Audio Weave
Bluray/Universal player-OPPO 105D
Dwight Angus is offline
post #5 of 19 Old 08-11-16, 05:51 PM
HTS Moderator
Reviewer
AudiocRaver's Avatar
Wayne Myers
I get a pretty strong "inside the head" perception with that part of that track. Strength of the effect will depend on head position and L/R balance, too. If the effect is softened with the new speakers, there might be a L/R matching problem.
AudiocRaver is offline
post #6 of 19 Old 08-11-16, 07:21 PM Thread Starter
Ken
Hi Dwight,
Thank you for the suggestion. Yes, I've tried multiple listening and speaker positions, including the 38% rule.
To Tony's point on alignment, my next step is to invest in a laser speaker alignment tool to make sure they're setup precisely. After that, I think I'll give up on this aspect of their performance.
I bought them for home theater, and I'm completely satisfied with them in that role. I would be completely satisfied with their two channel music performance as well, if I could just get this last measure of imaging/soundstage out of them.
post #7 of 19 Old 08-11-16, 08:19 PM Thread Starter
Ken
AudiocRaver wrote: View Post
Thanks for sharing your experience with that track, Audioc. I was beginning to wonder if I was wasting my time chasing a speaker quirk, instead of an expected aspect of their performance.
I'm not sure how precisely the L/R speakers would need to match, but I've set them up using Audyssey MultiEQ, and verified the outcome with Omnimic. The overall levels are matched well, but there is some variation in frequency response between them, but I'm not sure if it's enough to soften the effect. I also wonder if the drivers are not properly time-aligned, or if there are phase or cabinet diffraction issues that are softening the effect. I suppose I could try temporarily wrapping them in 1/4" felt- leaving the drivers exposed, of course- as a diffraction test.
post #8 of 19 Old 08-11-16, 11:04 PM
HTS Moderator
Reviewer
Wayne Myers
Following tomyvdb's lead, and your own suggestion, precision setup with laser distance meter is your best next step. At $60 to $80 they are not cheap, but after the first success that brings you a "NOW we're talking!" reaction, you will be glad for the expenditure. My trusty Bosch DLR130K, which I bought 6 years ago for about $80, has gotten as much use as any tool I own and is still going strong. I can't tell you the number of times that extra little bit of of setup precision has paid off with BIG soundstage/imaging rewards.
Edit: Watch out for early reflections, too, they can really mess up an effort like yours. Buy some pretty colored foam acoustical treatment squares and a couple of dollar store makeup mirrors, and start looking for possible 1st and 2nd reflection paths that reflect back to your speakers from the LP, and stick a square or two where you suspect there might be trouble. It can make a big difference.
post #9 of 19 Old 08-12-16, 12:48 PM Thread Starter
Ken
I'm using the impulse response feature of Omnimic to dial in identical speaker distances. If I'm using the impulse response incorrectly please let me know! Of course, I still need a laser for alignment and your Bosch unit looks as effective as anything.
I have seven 2'x4'x4" acoustic panels currently at first reflection points, but I need something on the ceiling, and there may be other early reflections, so I'll take your advice and get additional treatment.
Do you have a specific time/Db cutoff for what you consider to be problematic early reflections?
post #10 of 19 Old 08-12-16, 12:59 PM
ellisr63's Avatar
Ron
This is what i am going to be using... $6.50
Ron
My Home Theater
Yamaha CX-A5100, (3) JBL 2360A/EV DHA-1s, (3) 1/4 Pie bass bins, (2 pr) JBL 8340As, (2 pr) JBL 8320s, PS3, XBox One, (2) Intel NUCs, Redmere HDMI cables, Monster Signature HTPS7000, (2) Furman Power Conditioners, (2) DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diag) scope screen, Darbee Darcet, Panamorph UH-480 lens, (2) Crest Audio 2208, Yamaha XM-4080 & P7000s, (2) MiniDSP DDRC-88M, Oppo UDP-203
ellisr63 is offline
imaging or soundstage , question , stereo
