The Rogue Cronus Magnum Integrated Tube Amp has been around for a while. It has been reviewed in several publications and received a few awards... it is a highly regarded integrated tube amp.
The Cronus Magnum is part of the Rogue Titian series of tube amplifiers. Rogue set out with an engineering challenge to create a truly high end amp at what is considered entry level pricing. It offers outstanding performance and excellent build quality, assembled to the same exacting standards as their most expensive amplifiers... built entirely in the USA.
The few things I found lacking on the Cronus Magnum are XLR balanced inputs and the fact that you have to open up the chassis to change to a 4ohm speaker load.
Features
This is one of the tube amps I have considered for my two channel system.
Features
- All precision components
- Built in bias meter on amplifiers makes biasing a snap
- Fully tested, burned in, and auditioned
- Available in Anodized Black or Natural Silver
- Power requirements: 115V/60Hz
- 3 year limited warranty (6 months on tubes)
- MSRP $2,195
- 100WPC Magnum
- 20Hz-30Khz bandwidth
- KT120 output tubes, 12AU7 and 12AX7 small signal tubes
- Phono section gain 35dB (before preamp)
- (3) line level inputs, (1) phono input
- (1) variable output, (1) fixed output
- Headphone amplifier
- 4 and 8 ohm taps
- Remote volume control included
- Optional tube cage
- 18” W X 17.5” D X 5.5” H
- 50 lbs (55lbs shipping weight)
