HTS Two-Channel Speaker Setup Guide for a Deep Soundstage
74K views 123 replies 33 participants last post by  mark3141
#1 ·
Abbreviations
CCC - Cedar Creek Cinema, Sonnie's home-based cinema and 2-channel listening room
GM = Golden Mean, or Golden Ratio, which is 1.61803398875:1 ~ 1.618:1
GMP = Golden Mean Positioning, or positioning of speakers using Golden Mean guidelines
LP - Listening Position
Introduction
This will be a developing thread. Here is the quick start version, diagrams will follow.
The data and methods given here represent the best we have learned from Sonnie's Two-Channel Speaker Evaluation Events hosted by Sonnie at his home-based Cedar Creek Cinema (CCC). This guide was put together to help answer questions about speaker setup techniques learned during those events (links below). As further events occur and as pertinent additional information becomes available, it will be added to this guide.
$1,000 Speaker Evaluation Event, August 2013
$2,500 Speaker Evaluation Event, November 2013
$3,000 Speaker Evaluation Event, February 2014
Those events have been documented extensively, so they will not be discussed in this thread except where that discussion relates directly to stereo speaker setup for music.
Data from speaker setups in other rooms might be included if it clearly fits the approaches discussed.
Conditions and Caveats
These results occurred in certain room(s) with certain listening priorities. To summarize:
  • The primary goal is a wide, deep, detailed, cohesive, lifelike soundstage with sharp imaging and, where achievable, sharp soundstage depth acuity (few speakers can achieve really precise depth acuity, but when they do, your heart will stop - hopefully only for a moment).
  • The speakers go wherever they need to in order to sound their best, no consideration for WAF or convenience or pets or kids or anything else.
  • Minor sacrifices in frequency response may result in following these recommendations:
    • Toe-in angles help accomplish the desired soundstage and usually put the listener off the tweeter axis, resulting in minor high-frequency rolloff above 5 kHz - down 2 to 3 dB at 10 kHz, more above that.
    • Speaker positioning meant to minimize sensitivity to room modes has, up to this point, pretty much been ignored.
One might very well ask if there is any validity to assuming that these dimensions and ratios are at all universal. I have done detailed speaker setup work and achieve the desired soundstage and imaging results in many very different rooms and at multiple different LP/speaker arrangements in some of those rooms and the basic ratios and results have always ended up very close to those given here. In discussions with the evaluators at the CCC evaluation events they have indicated having similar experiences. So far there have been no major departures from these patterns. When there are, we will do our best to incorporate them in an informative way.
We are doing our best to convert the data into a useful rule-of-thumb setup guide format. But remember it all comes from the way certain speakers sounded to our ears and listening tastes in certain rooms. We hope our attempts here are useful, but they will certainly not apply to all. This is an experiment with the best of intentions, please take it as such.
There are many guides and approaches to room and speaker setup. This guide is specifically for reaching the goals stated above. We have ignored "equilateral triangle" rules and "aim at the listener" rules and rules that reduce room mode interaction and other considerations that common setup guides focus on, because they have different goals and do not help - in some cases they work against - the accomplishment of our defined goals. In putting this guide together, it was seen that the Golden Mean guidelines for reducing room mode interaction could be incorporated in determining logical setup starting points for various rooms. But adjustments from those starting points will usually be necessary, negating those benefits partially or completely.
We appreciate meaningful feedback, but will limit folding in data to that which we are confident meets our criteria and is compatible with our approach to finding that ideal speaker location. For starters, there is one data point from work in my home listening room. The setup was determined totally by ear without referring to notes about setting up the same speakers at CCC a few weeks earlier. The configuration arrived at independently matched very closely what we came up with at CCC in parametric terms, according to our rule-of-thumb approach. A single data point of confirmation, hopefully more will follow.
Defining our Terms
There are two parts to our process:
  • Determine the Starting Points
  • Make Adjustments
There will be a diagram for this eventually. For now, imagine a big letter T. The top of the T is the line from center to center of the fronts of the speakers (B in our table below), along the speaker plane. The "stalk" of the T (A in our table) is the line from the ears at the Listening Position, starting at the ear plane, to the center of that first line, the top of the T.
If your speakers are very close to front wall of your room (more guidance below), you will need to consider one more measurement. To illustrate it, we magically convert the letter T into a big + sign, with its vertical line going from the ear plane to the wall straight in front of the listener (C in our table).
Here is what our data shows:
Average B/A Ratio: 1.4 (ranges between 1.08 and 1.57)
Average C/A Ratio: 2.2 for NON-DIPOLES (ranges between 1.74 and 2.61)
Average C/A Ratio: 2.0 for DIPOLES (ranges between 1.59 and 2.31)
But we are going to use a value of 2.4 for C, regardless of speaker type, not 2.0 or 2.2. The reason follows...
Incorporating the Cardas Golden Mean Guidelines
In our experience, the C dimensions vary more than the A and B dimensions, and appear not to be super critical as long as C is "long enough." By increasing C only slightly from the values arrived at below, the speaker locations - if they can be set first and the LP can be placed accordingly, as in Option 1 below - line up with the popular Cardas Guidelines for room setup, minimizing room mode interaction. This is why the value for C is 2.4 for both dipoles and non-dipoles, rather than 2.0 and 2.2 seen below. From here forward, the value of C=2.4 will be used just to simplify matters.
Decision Point: The Simple Way or The Complex Way?
I have been told that I tend to over-complicate things. That might be true.
At CCC, the LP is fixed by room design, so that is our starting point when setting up speakers for evaluation. We have looked at Golden Mean Positioning of speakers, but the speakers almost always end up somewhere else for the best soundstage, so Golden Mean Positioning (GMP) of speakers is not a top priority.
Starting from the fixed LP and determining the starting point is easy for us. We have marked the spots where most speakers end up or thereabouts, and that is where we start. Easy. And, guess what, those spots fall right where A=1 and B=1.4. No surprise, our experience is what defined those values, as shown in the chart below.
The only reason the extra GMP calculations were added is this: if you have to figure all of this out from scratch for your room anyway, and have the flexibility to place the LP and the speakers wherever you want to, why not make a few extra calculations and make your starting points fall on GMP spots for your room? Maybe you will be lucky and with your speakers you will get the desired deep soundstage with the speakers on those very spots, and then you will have nice, even bass responses, too. Probably not, but maybe. It is worth the few minutes of extra effort to at least try, is it not?
But it does add extra complication that will probably be of little benefit to most. So my suggestion is this:
First time through, do it The Simple Way, with no GMP calculations, just to see how it works out with your speakers in your room and if you even like the results. If you do, then you can go about it the more complex way with the GMP calculations and maybe get smoother bass response, too.
Determine The Starting Points - The Simple Way
  1. Pick a spot for your LP.
  2. Measure from there (center of head, right between the ears) to the wall in front of the LP. That value is C. A good value for C is 12 ft in a medium-large room.
  3. Calculate A: C / 2.4 = A, the distance from the ear plane to the speaker plane, 5 ft in this example.
  4. Calculate B: A x 1.4 = B, the center-to-center distance between the speakers (center of the baffle plate, the tweeter is a good reference), 7 ft in our example.
  5. Place the speakers according to the definitions for A, B, and C.
  6. Now skip down to Make Adjustments below.
That's it, The Simple Way. When you want to try The Complex Way, it is given next.....
Determine The Starting Points - The Complex Way
Option 1 - Best - No Restrictions, Start with the Speaker Positions
Starting with your room width as 3.130 units ((1 + 1.618 + 1) x (1.4 / 1.618)), a weird number, the logic follows) place the speakers spaced between the side walls using units of 0.866:1.4:0.866 (this would normally be expressed as 1:1.618:1, but we have multiplied these numbers by 1.4 / 1.618 or 0.866 in order to keep with our A = 1, B = 1.4, C = 2.4 starting point) and 1.4 units (C - A) away from the front wall (measure from the center of the tweeter). This is good for reducing room mode interaction. Use C = 2.4, which also makes A = 1.
For example, in a room 15.66 feet wide, speaker spacing would be 4.33 feet from side walls, 7 feet from the front wall, and 7 feet apart (B). The LP would be 12 feet from the front wall (C) and 5 feet from the speaker plane (A). Following the Golden Mean (1.618:1), this places the speaker positions with left/right room symmetry where they will be least affected by room modes.
This all works out in most rooms anyway. We suggest always keeping the LP at least 3 feet from the back wall and its reflections, so in some smaller rooms the A, B, and C values must be reduced, keeping the same ratios, until that 3 feet guideline is satisfied. Then the Golden Mean guidelines are no longer satisfied.
Option 2 - 2nd Best - No Restrictions, Start with the Listening Position
Place the center of head of the LP equally between the side walls, as room symmetry allows, and make the distance from the front wall - dimension C - equal to 2.4 units of measure and the distance from the back wall 1.48 units of measure. Set the distance from speaker to speaker at 1.4 units of length (dimension B), and the distance from the speaker plane to the LP at 1 unit (dimension A).
For example, if the room is 19.4 feet long, locate the listener's ears 12 feet back from the front wall (C), leaving another 7.4 feet to the back wall. The speakers will be spaced 7 feet apart (b) and the LP will be 5 feet from the speaker plane. Following the Golden Mean (1.618:1), this places the listening position with left/right room symmetry where it will be least affected by room modes.
This all works out in most rooms anyway. We suggest always keeping the speakers at least 3 feet from the side walls, so in some smaller rooms the A, B, and C values must be reduced, keeping the same ratios, until that 3 feet guideline is satisfied. Then the Golden Mean guidelines are no longer satisfied.
Option 3 - 3rd Best - Other Conditions, Exceptions
If the LP or speaker location is set, use it as your starting point and determine A, B, and C the best you can given that limitation, also following the other guidelines in Options 1 and 2 the best you can. Remember that C is not critical as long as it is "big enough," so if conditions force it to be bigger than 2.4, that is fine. The same applies to mid- or near-field monitoring in a large room.
When speaker spacing gets overly wide, the soundstage and center imaging fall apart. Large rooms might also force you to abandon Options 1 and 2 for that reason (this is also covered in the next section.) If so, use a smaller-spaced configuration, focusing on A and B and ignoring C if it goes above 2.4.
Really Big Rooms
Our experience has been in rooms with ceilings under 10 ft (the CCC ceiling is 8.5 ft high) and with side walls and front wall within "spitting distance" of the speakers. Soundstage development as we like to hear it depends on diffused reflections from these surfaces, along with the more diffused later reflections from the back of the room behind the LP. In very large rooms, very long rooms, or outside, it is unknown how well any of this applies.
Make Adjustments
With dipoles, point the speakers straight at the ears at the LP. While listening, adjust the angles outward by equal increments (check angle symmetry with a laser pointer along a flat surface of the speaker cabinet to reference points on the LP chair) until the soundstage with a strong center, tight imaging, and good depth - it will not take much of an angle change from the starting angles for this to happen with dipoles, probably only a few degrees.
With a non-dipole design, start with the speakers pointed straight forward, not at the LP at all, but at the back wall (0 toe-in), and adjust them inward by equal increments while listening until the soundtage appears with a strong center, tight imaging, and good depth. This could occur anywhere from a few degrees of toe-in to 25 or 30 degrees, highly dependent on the speaker dispersion pattern.
You are listening for a soundstage that extends well beyond the width of the speaker spacing, tight, clear imaging that does not move on different notes or smear on sibilants, and - here is the magic element - you are not done until you achieve this - soundstage depth almost as deep as the width. With rare speakers, the acuity of the depth of positioning of voices and instruments will be down-to-the-inch precise in the depth dimension. In the width dimension this kind of precision is a minimum requirement for acceptable speakers, although many do not achieve it. Also pay attention to high-frequency response changes, as too wide an off-axis angle can cause excessive rolloff.
Make angular adjustments a few degrees at a time, or estimate an amount of change successive-approximation style. A $4 protractor might help, but mainly verify symmetry. Measure, measure, measure. A laser pointing device is a must, a laser measuring device is better. (Verify proper alignment of the laser within the body of the pointer.) Be precise to the inch, check angle symmetry to reference points at or around the LP to the inch, or - even better - to the back wall for greater sensitivity, assuming the relationship of your reference points to the LP have been measured or are known to be symmetrical by room design & construction.
After making an angle change, if you do not appear to have located the sweet spot at the LP, see if you can go and find it. Move around slowly while listening so you can determine how close you are to the sweet spot. Check the sound a few inches higher or lower, maybe much higher, or even in standing position. Be sure you have fond the right listening height for your speakers. Lean or move forward from the LP keeping your ears at the ideal height, like a "strutting rooster," move way up between the speakers, try behind the LP. Move your head side-to-side to see how sensitive the soundstage is to that movement. Experiment. Once you have located the best sweet spot for the current speaker setup, estimate how far the next adjustment should be to move it to the LP.
If the deep soundstage never happens, or if the center of soundstage seems weak or empty or has poor image clarity, start over with the speakers spaced closer together. If the deep soundstage occurs but you want to try to make it deeper, start over with the speakers spaced farther apart. If the angle adjustments seem too sensitive, start over with the speakers closer to the front wall, or the LP farther back from the speaker plane. If the angle adjustments do not seem to make much difference, start over with the speakers farther from the front wall, or the LP up closer to the speaker plane. If you notice excessive high-frequency rolloff, the off-axis angle is excessive (or the LP height might not be right), and you will need to adjust accordingly.
Tip: Drape a folded-up plushy blanket over the back of the LP seat if it has a back that approaches ear height. It will reduce reflections, improve the imaging and soundstage, and make them less susceptible to head movement and position.
When you find a setup that works, make careful measurements and write it all down, using reference marks for easy checks or resetting if something gets bumped or moved. Gaff tape for floor position and reference dots on the back wall for checking angle symmetry with a laser make a 10-second setup check possible. Do a quick setup check before every listening session.
Enjoy your great soundstage!:sn:
Table of Setup Data
Here is the data used to generate the spacing ratios.
The calculation of the A/B Ratio includes data for all speaker types. The calculation of the C/B Ratio is done with an averaging of values for only dipoles and a separate averaging of values for all non-dipoles.
No code has to be inserted here.
(18.21+1.46)/14~1.405=1.4
(22.65+1.81)/11=2.22364~2.2
5.85/3=1.95~2.0
** Conforms with Cardas Golden Mean Guidelines under some conditions, so C=2.4 is always used for convenience and simplification. Explained above.
Early Reflection Guidelines:
Perfect room symmetry is not absolutely necessary. General symmetry plus a few treatments probably do the trick. A room with longer RT60 times might have "unbalanced spaciousness" effects where one side sounds bigger than the other. My own listening area is far from symmetrical, but RT60 is quite low and I do not notice anything like this. With longer RT60, absorptive treatment can help balance this effect out.
Early reflections can really throw off the imaging and soundstage. Treatments here are very beneficial. My own rules for early reflections:
  • Less than 5 mS (of additional delay relative to the delay of the direct wavefront from speaker to LP; on an impulse response plot, it will be easy to read that relative delay directly): disruptive to image clarity, must be absorbed.
  • Between 5 mS and 15 mS: must be VERY summetrical (direction and delay time) and must be perceived as coming from the vertical line of sight from speaker to LP; if the reflections are NOT coming along the vertical line of sight from speaker to LP, or if not symmetrical, then either absorb or scatter them. Scatter them with a reflective surface pattern that does not reflect ANY of the sound directly at the LP (I have gotten into long arguments about this last point, but experiments have proven to me that it is very important for the best imaging, and I do not care what expert says otherwise, they are WRONG).
    • Example 1: ceiling reflections (flat ceiling) would be on that vertical line of sight, and might be only delayed by 8 mS or so, and would probably be highly symmetrical. They are OK, though, will not smear the image L or R, and will add a small amount of spaciousness to the sound, as well as some height info to the soundstage.
    • Example 2: in a symmetrical room, reflections off the side walls, if only a few feet from the speakers, would be symmetrical, and would fall within the 5 to 15 mS window, but would NOT be on the vertical speaker to LP line of sight, so imaging would be smeared and softened, so they are not OK. Absorb or scatter (see above).
    • Example 3: Reflective panels on the front wall on the vertical line of sight from LP to speaker could be angled so the reflections are on or very close to that line of sight and are very summetrical and fall in the specified delay range. These are OK, can enhance the soundstage and imaging. However, the natural reflection points on the front wall just inside those panels would not fall on that line of sight and would mess up the imaging. Absorb or scatter (see above) at those natural reflection points.
  • More than 15 mS: less critical. In general, better scattered, and the direction of reflection is not important, although randomized is better.
Related Articles
A Soundstage Enhancement Experience, refining and enhancing the soundstage and imaging with MartinLogan ESL hybrid electrostatic speakers in Sonnie Parker's Cedar Creek Cinema, March of 2015.
#5 ·
With the goal of deep soundstage in mind, there was nothing we tried with speakers close to the wall that helped create it.
With dipoles placed well out into the room and giving the desired soundstage depth, placing an absorptive panel directly behind them to disrupt the rear wave will flatten that soundstage right out.
Some room behind the speakers seems to be a necessity for allowing that quality to develop.
#4 ·
Abbreviations
Place the speakers spaced between the side walls using units of 0.866:1.4:0.866 and 1.4 units away from the front wall (measure from the center of the tweeter). This is good for reducing room mode interaction. Use C=2.4, which also makes A=1.
For example, in a room 15.66 ft wide, speaker spacing would be 4.33 feet from side walls, 7 feet from the front wall, and 7 feet apart (B). The LP would be 12 feet from the front wall (C) and 5 feet from the speaker plane (A). Following the Golden Mean (1.618:1), this places the speaker positions with left/right room symmetry where they will be least affected by room modes.
This all works out in most rooms anyway. We suggest always keeping the LP at least 3 ft from the back wall and its reflections, so in some smaller rooms the A, B, and C values must be reduced, keeping the same ratios, until that 3 ft guideline is satisfied. Then the Golden Mean guidelines are no longer satisfied.
For example, if the room is 19.4 ft long, locate the listener's ears 12 ft back from the front wall (C), leaving another 7.4 feet to the back wall. The speakers will be spaced 7 ft apart (b) and the LP will be 5 ft from the speaker plane. Following the Golden Mean (1.618:1), this places the listening position with left/right room symmetry where it will be least affected by room modes.
I'm usually pretty decent with math and this is pretty simple math, but I'm having trouble visualizing how the ratios are derived/applied. May I request a simple drawing to illustrate what is happening here? 0.866:1.4:0.866 isn't sinking in for a starting reference. What is defined as 1?
#6 ·
Diagrams will definitely follow, give me a few days.
I tried to do it so A is always = 1, B = 1.4, C = 2.4
They are the core dimensions, most important to getting that soundstage, so everything else builds around them, although the order of doing the calculations might be in reverse.
The 0.866 value then relates to B=1.4 by the Golden Mean (1.618): 1.4 / 1.618 = 0.866
#8 ·
Awesome write up!! Thanks. Good thing the phone has a calculator:) my room is not cooperating, though. My LP is 15' back from the front wall, but the room is only 12' wide, so I'd have the speakers in my wife's seat on the side couch to make the ratios work. :). The speakers would be so close together, I'm leaning way forward to get close. But it's working for depth of stage, that's for sure!!!
#12 ·
I noticed the results being observed in the CCC shootouts. This peaked my curiosity so I gave it a try.
The depth you guys described was there for sure. It was as if I could peer in to the music beyond the speakers, while still pinpointing where each sound was coming from. This formula worked in my listening room.
I can't leave the speakers there, of course. Fortunately my sweet spot near the front wall (where B/A = 1.22) yields even better results with regard to depth acuity. It so happens to yield flatter frequency response as well. I may be able to credit this to the fact that I have 4" panels on the front wall behind each speaker. Also, the side wall 1st reflection points are non existing due to openings.
I've got pics but the app keeps crashing.
#14 ·
Very Very good guidelines, your attention to detail is something I will forever be amazed at.
I think if we all follow these guidelines we will be in a much better place, even if small adaptations are needed, these numbers will bring us all so close to correct.
This kind of takes the worry out of being an audio nut to be sure. Well Done Wayne. :hail:
Now can you also cure the neurosis ?? :rofl:
#16 ·
Excellent write up! I am going to try this when I start building our garage Home Theater. I will have my 3 Klipsch La Scalas behind the screen but the cavity where the speaker will be will be around 4' deep. I know it will not be optimum but I hope it will allow me to get a deeper sound stage. I did something similar to this years ago when I had my Martin Logan Sequels, and I had an awesome sound stage. Thank you for bringing this up as it is definitely lacking in my current setup.
#20 ·
I wish you guys had published this in 1976 when I bought my first Magneplanars.:D Yeah, I know there was no internet then.:bigsmile:
I'll be recommending this thread to others. You guys manage to do more for your posters than just about any other site. I just want you to know that I for one appreciate it.:T
#22 · (Edited)
Hello AudiocRaver!
First off, Kudos for your innovative approach and eloquent write-up! :yay2:
Start Sidebar
Is that proper forum etiquette? Why does everyone else refer to you as "Wayne" :huh: I guess I should start off by asking forgiveness for such transgressions :cop:. Please understand I'm fairly inexperienced with forums (hey, you can't expect all that much from an old geezer who got his first cell phone only a year ago) :unbelievable: !!!
Aside from addressing you properly, I also mean to quote part of your message, and think I've followed the instructions, but I don't see it while writing my "Quick Reply." Have you guessed yet I'm from the "self-esteem" generation? :flex: :rolleyes:
When I hear from the forum-police :cop: I'll know I went too far :hide:
End Sidebar
Frame of reference for the questions that follow:
My Revel Ultima Salon's (original model) have curved front baffles interrupted by artsy grill assemblies, sloped and rounded tops, as well as slanted backs.
Now for my questions (which relate to laser alignment in case the intended quote doesn't appear):
  1. I believe your intentions are to align speaker toe-in regardless of actual driver position or angle, correct? Results should be the same for odd-shape designs as for typical box enclosures, provided identical measurement criteria are afforded to both the left and right channels.
Soooooooo......
  1. Given your emphasis on the importance of measurement accuracy, it seems crucial to have a reliable and repeatable method for laser mounting, especially in the case of polygonal and curved cabinet enclosures. Now my next question may not be realistic given the variety of available laser devices, but can you offer any guidelines for effective mounting techniques in those cases? Please don't say "duct tape" :) I'm guessing a laser with bubble level to indicate relationship between speaker mounting surface and horizontal plane parallel to floor?
    Thanks in advance for any advice!
    Louie
#23 ·
I use my regular name on the reviews I post on HTS, so I get referred to by that sometimes.
The assumption is that a speaker pair has left/right symmetry and they are being aligned to that symmetry.
Soooooooo......
    Louie
Most of what is accomplished with lasers amounts to repeatability (the speaker is aimed the same as it was last time) and symmetry (left and right toe-in angles the same).
A laser pointer can do this pretty well. I like one that has a beefier body diameter so it is easy to grasp and handle, and a metal push-button switch (they last longer). You have to watch alignment of the laser in the body, many are not precisely aligned. You can check it by rolling it slowly on a counter top while holding the button on, and noting the range of up/down motion on a far wall. At the center of that range, the "reference" surface of the body of the pointer is touching the counter top. Mark it somehow and always orient it the same way when using it.
But it does need a flat side to rest on, and speaker designers generally do not think of our practical setup needs, or they might build lasers into their speakers to help us out.
Speakers that have all curved surfaces are good for sound and hard to align. We have worked with a few like that. The laser distance meter - like the Bosch DLR130K Digital Distance Measurer Kit - sometimes works better. The laser is well-aligned relative to all surfaces including the rear end. It can sit across a tweeter cone or, with a very flat piece of wood taped to the back, across a midrange or woofer driver cone for alignment purposes. Sometimes a speaker cone is the only flat reference point available.
Strictly as a repeatability reference for each individual speaker, a laser sight, like the UTG Combat Quality Tactical Laser Sight with Adjustable Windage and Elevation can be attached with thick double-sided tape. This one has a pressure switch on a short cable so it can be activated without touching the laser itself. A target point on a wall allows for quick reference checks to ensure a speaker has not been moved or nudged.
Hope that helps.
#24 · (Edited)
Wayne, I decided to try something which violates a couple of 'rules' which I took to be inviolable. All I can say is that it works brilliantly for Magnepan 3-series speakers (a number of us have recently adopted the arrangement and our results are uniformly excellent). It's specific to dipole designs that aren't of the single element variety. It's referred to as the HK/Limage setup, which places the speakers (tweeters to the inside of the room) quite close to the side walls with no toe-in at all - absolutely perpendicular to the side walls. The recipe calls for a placement which is approximately 40% into the room, but it seems to really only require somewhere between 8 and 9 feet off the front wall (I can get 8'7" with my cables).
I scoffed (inwardly) at the suggestion when I first read about it. After all, the manufacturer is pretty clear about not setting their speakers up in such a fashion. Well, I must now feast on crow, because this has resulted in the most impressive soundstage I have EVER experienced from a stereo system. I think one of the requirements is that the listening room should resemble a bowling alley as mine does - quite long and comparatively narrow.
The amazing thing is the variability of the scale, which always seems appropriate to the music being played. If I'm listening to a jazz ensemble or a string quartet, the sound is intimate, with accurately scaled instruments. If, on the other hand, I'm listening to something 'big', it can explode my room into a massively open space with sound apparently emanating from points in space which completely engulf me. In all cases, these large speakers completely disappear, as do the confines of my room. I think the most impressive thing is that this amazing soundstage doesn't come at a price in any other area (I expected frequency response aberrations, but I don't perceive any - haven't done any measurements yet).
It's positively magical.
#25 ·
That's awesome! I would expect that with a good set of Maggies, an open-opportunity floor plan, and gobs of time and patience one could achieve something very special. With Wayne pushing the envelope of experimentation I figured it was a matter of time before someone reported back with reports of audio nirvana. Kudos and enjoy!
Seth
#26 ·
Kevin360:
My wife is going to hate you. The only way I can try what you are suggesting is to totally empty out my living room. Hopefully some flowers and a few Amazon book orders will make things right on the homefront.
Actually it sounds like it might be similar in principle to what I stumbled on with the Martin Logan ESLs, with the rear reflected wave playing a much bigger role in the development of the soundstage. And there is a rear wave path which reflects off the sidewalls and then front wall, providing a little extra delay, which gives the soundstage a.very dense presence with incredible depth acuity.
You did not mention listener position relative to the other dimensions. Is it roughly twice as far from the front wall as the speakers are?
Interesting that you are not noticing high frequency rolloff from being off-axis as far as you are. The Maggie's are so directional. The rear wave is definitely making a difference in the perception of high frequencies and you are less off-axis in the reception of that rear wave off the front wall. And the tweeter to the inside of course is helping as well.
I appreciate the post. It sounds like you have experienced the kind of huge, deep, densely detailed soundstage that is almost mind altering and completely addictive. Our little speaker setup guide is due for an update, your information will certainly be included as a possible approach with dipole speakers. Thanks again.
#27 ·
My listening position is fixed at 250” off the front wall, so it's a bit more than twice the distance from the front wall as the speakers. More importantly, that's 155” off the rear wall (~38% - a good distance for modal considerations). The plane of the speakers is 103” off the front wall, and the subs are positioned another 55” out (~38%). The outer edges of the speakers are 15” off the side walls, which is as close as I can get them due to ceiling shape. It's close enough to get a fair amount of side wall reinforcement of the bass.
I'd be surprised if this worked well with the MLs. The true ribbon tweeters are anything but directional, having nearly perfect 360 degree dispersion (well past 20KHz) – the benefit of being so narrow. Actually, one of the things that I feared was that the ribbons would become intolerably dominant, but that didn't happen. With a single element dipole, the off axis response is going to be a problem. At least, that's what I'd expect, but these Maggies keep violating my expectations (I've tried some weird things that worked), so what do I know?
I know one thing. This setup works exceedingly well with the 3-series Maggies (3.7s, in my case). Indeed, this (huge, deep, densely detailed soundstage) is intoxicating. For some time, I've coveted MBL's Radialstrahlers, but this arrangement images better than anything else I've ever heard – at least, in a long rectangular room.
#28 ·
Of course, I was forgetting the ribbon tweeters! That is obviously (now that you have reminded me!) why the HF response does not suffer.
As far as working with the MartinLogan design, my approach with them is to get the desired soundstage, then use a single HF shelf filter (in foobar2000) to lift the high end back up to almost flat. As far as reflection paths are concerned, it would seem they would create the soundstage pretty much the same.
Alas, my project backlog prevents me from barging into a new setup experiment right now. The approach, while not intuitively obvious, is certainly "sound," ;) and confirms in a fashion that my own findings are valid and not total insanity! Thank you for the additional detail. I am certain you will enjoy the fruits of your experiment immensely!
#29 ·
I followed your guide and I ended up losing a lot of low frequecies at the listening position. I ended up adding two large bookshelve speakers and an amp to my LFE channel and ran a 80hz cross over.
Are you guys really getting sub 60hz bass in your room with your speakers 6 feet off the front wall?
My setup is different now but this was my failed setup.
Note: 2 speakers on the floor (Left and right) close to the wall.
#30 ·
Did your soundstage change/improve? I have subs in all 4 corners. This allows me to place my mains for optimum soundstage while leaving the sub system to handle <80hz.
