Cheap 2.1 channel amp?
5K views 11 replies 5 participants last post by  jamesfrazier
#1 ·
I have a friend who has 2 very cheap speakers that came with a isymphony DVD. Well the DVD player was where the powers to the speakers went to and it is now dead. She could care less about sound quality, and I would guess 20 watts + would be sufficient. I also have her an old Yamaha powered sub woofer she would like to be able to play. If there anything out there that can provide this? Lepai amps do not have sub outs and the only other 2.1 amplifiers I've come accords are 100 watt/ch and cost around 120 bucks..
#2 ·
A stereo receiver with a sub out will be a challenge to find for under $200
I did find this Onkyo Receiver for $179 at Accessories4less and it has a sub out as well :)
#4 ·
Finding a cheap stereo amp wont be an issue but one with a sub out wont be as thats a new thing that has not normally been included.
#6 ·
:R OK stupid Cheap.....
http://www.parts-express.com/dayton-audio-dta-100a-class-t-digital-mini-amplifier-50-wpc--300-383
Your Sub if power will probably have high level inputs. So your cheap speakers are hooked up to the sub via those and the amp is also hooked up to the sub via those inputs.
That's about a bargain bin basement cheap as your going to get unless you go down to 25 watts
http://www.parts-express.com/lepai-...dio-mini-amplifier-with-power-supply--310-300
OR you find something a craiglist or whatever your local online used market is
#7 ·
Not alot of low end subs have high level inputs and given she probably had a very low end sub its unlikly that it would function that way but good point :)
What JBL sub does she have?
