I'm looking for an affordable system to help calibrate my projector and my television. This system would need to come with everything I need to calibrate minus a PC.
Bumping this to see whether the CalMan/i1 Display2 is still the recommended entry-level package for PJ calibration. I have a Mits HC4000 firing at a BW painted screen so it should be pretty close after basic brightness/contrast, but going through a cal sounds fun/interesting/beneficial enough that I'm interested in giving it a try. I'm not sure $400 for the 'pro' version fits in the budget, though.
i1 Display 2's are pretty much gone. They haven't been made in over a year, so best you can hope for is new old stock. If you follow the i1 Display 2 much, then you'll know those meters start to drift after a year or so.
Currently that leaves the spyder 4 and our spyder 4 based C1 ( a spyder 4 with offset tables). Above that is the i1 Display Pro (3) that is a much much better meter than either the spyder 4 or the i1 d2.
Thanks for the quick feedback. I'll have to do some thinking on this. Having gotten used to the $200-ish level, the jump to $400-ish is enough to give me pause, at least until I convince myself that it's needed.
I'd dismissed the rental idea since my time is rather unpredictable and as a 'tweaker' to some degree, having the unit on hand for experimenting with seemed a more interesting option. Maybe I need to reconsider that.
Well if you already have CalMAN, you can just by an i1 Display Pro from anywhere and use it.
Related Threads
742.3K posts
170.9K members
Since 2006
