LightSpace DPS (up to 21-Point Cube 9.261 Colors Free Display Check Version) - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 31 Old 07-14-15, 04:00 PM Thread Starter
ConnecTED's Avatar
Re: LightSpace DPS (up to 21-Point Cube 9.261 Colors Free Display Check Version)
LightSpace CMS 7.0.1.2172 (13 July 2015) has just released.
This is minor bug fix release. Not affecting LightSpace's Engine. Generally, for LightSpace users that have performed a recent display profiling and see that a new LightSpace has been released where it features some improvement in colorspace correction (for example), the users don't need to re-measure again their displays. It require only to install the new LightSpace version, load the latest measurement file and generate the ColorSpace conversion to get the new 3D LUT correction file and then upload it to their 3D LUT hardware device or to their 3D LUT capable monitors. This saves a lot of time.
Download LightSpace CMS Demo or Upgrade for Licensed Users
Request Free Version License for LightSpace DPS (Display Profiling System)
Software: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
Video Processors: eeColor 3D LUT Box, Darbee DVP-5000 - Pattern Generator: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1Display PRO, Chroma 5 PRO
ConnecTED is offline
post #12 of 31 Old 08-28-15, 11:03 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.0.3.2214 (28 August 2015) has just released.
Changes
-- Added Max Exposure setting for CR-100 probe
-- Added Integration Time setting for CR-100 probe
-- Corrected Sliders operation
-- Corrected Prisma Upload functions
-- Allow BT1886 to be saved with changed gamut values
-- Added Kroma monitor integration
-- New LUT formats added
Download Links
post #13 of 31 Old 09-30-15, 02:40 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.0.4.2251 (28 September 2015) has just released.
Changes
-- Anisometric Profiling patch sequence option
-- Canon display integration
-- Windows 10 COMs port issue resolved
-- Added TVLogic Binary LUT format
For OLED's/HDR displays it's been added an Anisometric Profiling patch sequence order option to LightSpace.
Anisometric sequences are better suited to displays that have any form of ABL, such as Plasmas and many OLEDs, and which also includes HDR displays where Sequential patch ordering can cause display overheating (overheating can actually be an issue on any display that has high peak luminance outputs, as it can cause the display to drift.
Download Links
post #14 of 31 Old 10-21-15, 08:00 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.0 Beta is available for testing / close for final release.
Changes
-- Altered Scroll Bar operation.
-- Changed operation of the Luminance Thermometer.
-- Added Min/Max Luminance to ‘Options’ menu for Manual Measurements.
-- Added new RGB and Delta-E Bars Widget to Calibration Interface.
-- Changed AEQ/Kroma display Upload function.
-- Changed Gamma and DifGamma graphs to show RGB values.
-- Added support for PR-653 Cinebrate probe.
For those who want to take a test drive you can contact LightIllussion or send me a PM to provide the download link.
For LightSpace users, there been added 2 new helpful User Guides:
For Manual Display Calibration: http://www.lightillusion.com/manual_...ots_guide.html
For 3D LUT Calibration: http://www.lightillusion.com/lut_cal...ots_guide.html
post #15 of 31 Old 11-03-15, 11:22 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.0.2292 (02 November 2015) has just released.
Changes
-- Added % values option to scroll bar
-- Added support for Eizo CG248 and CG318 4K monitors
-- Set EBU default Gamma to 2.4
-- Correction for DigfGamma graph plot
-- Change to correct Resolve 1D Shaper LUT extension
-- Fixed occasional crash when matching Profiles to Profiles
Download Link
post #16 of 31 Old 11-11-15, 03:57 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.1.2303 (08 November 2015) has just released.
Changes
-- Added Drift Compensation for display & probe time based drift
-- Fixed ‘Ftl’ Luma graph & value display issues introduced in 7.1.0
-- Corrected PDF Report Luma values, also introduced in 7.1.0
-- Added larger Cube display options to 3D Cube viewer
-- Corrected ACES Gamut plot triangle
Download Link
post #17 of 31 Old 11-18-15, 09:29 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.1.2304 (17 November 2015) has just released.
Changes
-- Fixed 'Ftl' Luma graph value display issues introduced in 7.1.0 and first 7.1.1 release.
-- Corrected PDF Report Luma values, also introduced in 7.1.0 and first 7.1.1 release.
-- Added Prepend/Append capability to 'Maths' function.
Download Link
post #18 of 31 Old 11-20-15, 04:48 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.1.2305 (19 November 2015) has just released.
Changes
-- Corrected RGB Bars Widget display
Download Link
post #19 of 31 Old 11-22-15, 06:54 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.1.2307 (19 November 2015) has just released.
Changes
-- Fixed RGB Bars Widget display
Download Link
post #20 of 31 Old 01-14-16, 07:00 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.2.2341 (14 January 2016) has just released.
Changes
-- Added BBC HLG Gamma profiles for Rec709, Rec2020, and P3
-- Added graphing for ST2084 and BBC HLG standards
-- Apply Probe Offset data when setting display Min/Max Y in Options
-- Corrected Manual Measure values when using BT1886 as Target colour space
-- Corrected various FtL value display errors
-- Added image extension to 'Save As' from LUT preview function
-- Increased Cube Size for ACES CTL export
Download Link
21point , check , colors , cube , display , dps , free , lightspace , version
