LightSpace DPS (up to 21-Point Cube 9.261 Colors Free Display Check Version) - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 37 Old 05-19-16, 04:41 PM Thread Starter
ConnecTED's Avatar
Re: LightSpace DPS (up to 21-Point Cube 9.261 Colors Free Display Check Version)
Getting Started with LightSpace DPS Part 1 - a training video from Mixing Light: https://mixinglight.com/portfolio/ge...ce-dps-part-1/
Software: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
Video Processors: eeColor 3D LUT Box, Darbee DVP-5000 - Pattern Generator: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1Display PRO, Chroma 5 PRO
ConnecTED is offline
post #22 of 37 Old 05-24-16, 05:58 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.3.2412 (23 May 2016) has just released.
As part of Light Illusion's continued development process for LightSpace CMS a raft of new developments have been released today, and include:
Added ability to select graphs and data for PDF report export.
Increased CSV sequence size to 16000 patches - added warning if max exceeded.
Corrected Luma thermometer display error with Cube profiles.
New colour engine algorithms for LUT generation - specifically low gamut displays.
Added Set Min Luma option when generating LUTs.
Corrected possible error in reporting Limit Max Luminance peak value.
Corrected CR probe Matrix Call function (occasional call error).
Moved some processes to separate threads to prevent 'Not Responding' messages.
Fixed a bug with Manual Probe Matching where patch shown would be just black.
Moved 'Name LUT' box to bottom of Colour Space window for easier operation.
Added 'Pause' capability to Display Characterisation profiling.
Integrated Jeti 1501 Spectrophotometer.
Added user Company Logo option for PDF report export.
Corrected BT1886 Gamma Graph display error.
Added Batch LUT Generation and Export from Display Profile.
Increased space for IP addresses in Network Manager.
Corrected Colour Space typo for ST2084 in Manage Colour Spaces.
Stop displayed values in Calibration Interface 'wrapping' when values are high.
Fixed crash if long profiling sequences are performed back-to-back.
All new features and developments are provided free to existing customers, continuing Light Illusion's approach of no additional costs or yearly support fees for all its software systems.
Download Link
post #23 of 37 Old 07-14-16, 12:58 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.4.2428 (07 July 2016) has just released.
As is usual for Light Illusion's continued development process for LightSpace CMS a raft of new developments have been released today.
Release Notes
Added new Colour Engine algorithms for poor gamut display calibration. (Fit Chroma and Fix Chroma use the new Colour Engine)
Added Murido SIX-G integration.
Added further Prisma LUT Box integration. (Additional Prisma integration will be added in the next release)
Changed the way Probe Connect/Disconnect works. (To make the process more robust)
Fixed crash when using CDL Convert menu.
Corrected Batch LUT Conversion issue with 'browse to folder' missing.
Fixed potential issue if probe still finishing a measurement when 'Options' selected.
Fit Chroma & Fix Chroma
Fix Chroma and Fit Chroma use totally new Colour Engine algorithms in generating the final LUT, and offer a potentially superior calibration alternative for displays that have good RGB channel separation (low cross-coupling), or for displays that prove difficult to calibrate via Peak Chroma or Peak Luma, specifically if the display has a gamut that is significantly lower than the target colour space (such as calibrating to Rec2020).
Download Link
post #24 of 37 Old 08-14-16, 04:43 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.5.2444 (08 August 2016) has been released.
As is usual for Light Illusion's continued development process for LightSpace CMS a raft of new developments have been released.
Release Notes
Added integration for FSI BoxIO LUT Box.
Fixed incorrect PDF Report error message.
Fix Batch LUT Conversion crash introduced with last fix.
Download Link
post #25 of 37 Old 08-26-16, 06:40 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.5.2452 (25 August 2016) has been released.
Release Notes
Added new 'log' and '?' operators to the Maths function (see http://www.lightillusion.com/lut_manual.html#maths for additional info)
Improved HDR (ST2084) options for LUT Generation
Improved Min/Max Luminance function in LUT Generation
Ιmproved integration for FSI BoxIO LUT Box
Changed operation of Max/Min Luma during LUT Generation
Download Link
post #26 of 37 Old 10-05-16, 07:27 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.6.2475 (28 September 2016) has been released.
Release Notes
Removed FtL as a Units option, as FtL Should no longer be used for calibration
Added first integration for Radiance Pro UHD/HDR/WCG workflows
Changed LUT naming to enable specific user names to be exported with the LUT
Added ST2084 Roll Off options for on-set and Home Cinema use
Fully integrated Murideo SIX-G (new GUI with all options)
Additions to FSI BoxIO LUT Box Upload options
Altered Rec709 and sRGB defaults to 2.4 and 2.2 power law gamma
Download Link
post #27 of 37 Old 10-25-16, 07:21 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.6.2486 (24 October 2016) has been released.
Release Notes
Added CR-300 Photospectrometer probe.
Fixed issue with Manual Measure and used defined ST2084Colour Space.
Corrected issue with Radiance LUT upload with excessive LUT changes.
Fixed bug with Radiance ABL patch generation.
Fixed issues with some Murideo SIX-G menus and test patterns.
PhotoResearch probes now work with Windows 10 (make sure Windows 10 is fully updated).
Changes to Jeti probes integration and added ‘Sync’ function for Spectraval probes.
Download Link
post #28 of 37 Old 11-12-16, 01:10 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.7.2501 (12 November 2016) has been released.
Release Notes
Adjusted Gamut Coverage calculation on LUT Generation.
Fixed lock-up with Gamut Warning LUT generation.
Added FSIBoxIO updates.
Fixed MadVR TPG patch delay with Display Characterisation.
Changed options for Jeti Specraval probes ‘sync’ functions.
Changed i1D3 ‘bad reading’ error message response to stop probe disconnect.
Added 0-1023 -> 64-1023 to LUT manipulation tools for ‘Super White’ capability.
Download Link
post #29 of 37 Old 11-18-16, 07:36 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.7.2511 (18 November 2016) has been released.
Release Notes
Added TVlogic direct 3D LUT Upload capability.
Added indexing for exporting multiple LUTs with same extension.
Corrected CR-100/250/300 timeout issues.
Fixed CR-100 Exposure Multiplier.
Added fix for potential ‘Runtime’ crash aborting long exposures.
Added option to Lumagen to leave input setting when uploading a Null Cube.
Changed default delta-E to 2000.
Download Link
post #30 of 37 Old 11-26-16, 05:24 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.7.2514 (22 November 2016) has been released.
Release Notes
Added ‘Multiplier’ for Projection based HDR.
Added ‘MODE’ option to Lumagen TPG.
Added option to Lumagen to leave input setting when uploading.
Download Link
21point , check , colors , cube , display , dps , free , lightspace , version
