Mitsubishi WS-55511 Wont turn on - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Discuss Mitsubishi WS-55511 Wont turn on in the Home Theater | Audio and Video forum; Mitsubishi WS-55511 Wont turn on I have a Mitsu WS-55511 that wont turn on. It goes thru the 45 second green flashing when plugged in, ...
Old 05-10-08, 10:52 AM   #1 (Link)
New Member
Alias: Richard
Loc: Hooper, Utah
User: #20593
Since: May 2008
Ixtlan is offline
I have a Mitsu WS-55511 that wont turn on. It goes thru the 45 second green flashing when plugged in, then when I try to power on it does the 3 second green led and shuts off.
I have replaced the infamous DM Board capacitors and the Convergence IC. Also I have tried the disconnection of the front panel and still will not turn on. All the pico fuses are good and the switched power checks are good.
The error test (menu and input for 5 secs) returns code 12 (gtg).
I did notice that the left most CRT (looking at TV from front) will arc in the lower most part of the glass tube where the other two do not when first powering on.
Is this normal?
Any ideas as to where to go next?
Ready to push this in front of a bus
Thanks for any help.
Old 05-10-08, 11:16 AM   #2 (Link)
New Member
Alias: Richard
Loc: Hooper, Utah
User: #20593
Since: May 2008
Ixtlan is offline
Re: Mitsubishi WS-55511 Wont turn on
Now it is flashing (error test) 23 for "Loss of Horizontal Deflection".
Old 05-10-08, 12:28 PM   #3 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
If you see arcing in the CRT, I would disconnect that CRT and see if it runs.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 05-11-08, 09:13 AM   #4 (Link)
New Member
Alias: Richard
Loc: Hooper, Utah
User: #20593
Since: May 2008
Ixtlan is offline
Pulled the board off and it still arced so pulled all the plugs and the red wire from the HV Block and arcing went away, and the code changed back to 12.
Still wont fire up though.
Old 05-11-08, 10:00 AM   #5 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
Sounds like you may have a short in the CRT.
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Similar Threads
Mitsubishi WS-55511 Problem falcon935 Video Displays and Processors 20 05-21-08 11:50 AM
Help Mitsubishi VC4543a wont power up Carbon12 Manufacturers Service and Support 8 01-25-08 11:27 PM
HC1500 wont turn on... grrrr Blasphemy Home Theater Projectors 2 01-18-08 09:08 PM
Mitsubishi WS-55511 Red Convergence sasquachh Manufacturers Service and Support 1 12-31-07 11:28 AM
Mitsubishi 42" widescreen will not turn on stymee Manufacturers Service and Support 15 11-29-07 04:12 PM
Mach 5 Audio
