Any better low cost 37" 1080p TV than Sceptre? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Discuss Any better low cost 37" 1080p TV than Sceptre? in the Home Theater | Audio and Video forum; Any better low cost 37" 1080p TV than Sceptre? I'm curious is there a better deal than the Sceptre x37sv Naga LCD TV/monitor available? It has separate ATSC/QAM and ...
Old 04-27-06, 05:54 PM   #1 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is online now
I'm curious is there a better deal than the Sceptre x37sv Naga LCD TV/monitor available? It has separate ATSC/QAM and NTSC tuners plus works very well as a 1080p computer monitor. Costs are around $1500 via internet sources including Costco. The closest to it has been the Westinghouse 37" LCD but it did not have an ATSC/QAM HDTV tuner the last time I checked.
Bob
Old 04-28-06, 08:05 PM   #2 (Link)
Tech'y Shackster
Alias: Bob
User: #25
Re: Any better low cost 37" 1080p TV than Sceptre?
To answer my own post here is some info about the new (just becoming available at Best Buy) Westinghouse monitor:
The Westinghouse LVM-37W3 37" LCD Video Monitor is a state-of-the-art 1920 x 1080 progressive scan LCD display brings you the ultimate in Digital video. It's been optimized for use with the latest High Definition sources; enjoy HD digital cable, HD satellite and a digital game console -- all with the very highest in digital picture quality. PC and notebooks users can also enjoy the same fat pipe and the industry best Genesis Display Perfection technology. Multiple connection choices, including 2 DVI with HDCP connectors, lets you connect to a PC and the latest multimedia video sources. Amazingly thin for its size, you get 37 inches at only 4.5 inches deep (without the base), allowing you to mount this stylish monitor on your wall.
Displays up to 16.7 million colors
Aspect Ratio: 16:9
Contrast Ratio: 1000:1
Viewing Angles: 176° Horizontal, 176° Vertical
Compatible Modes: 480i, 480p, 720p, 1080i, 1080p
Native/Optimum Resolution: 1920 x 1080
Supported Resolutions: 1920 x 1080, 640 x 480, 800 x 600, 1024 x 768
Twin 20 Watt speakers
Picture-in-Picture display
Freezing Picture
3D Noise Reduction
Inverse 3:2 pulldown
3D Video Processing, 3D Comb Filter
CCS (Cross Color Suppressor)
Response Time: 12 ms
Brightness: 550 cd/m2
Input connectors:
Outputs:
Lamp Life: 50,000 hrs.
Color Gamut: 75% NTSC
Color: Silver
Dimensions(HxWxD): 36.6" x 23.0" x 4.5" without base
Dimensions With Base: 36.6" x 28.5" x 8.4"
Weight: 44 lbs. without base
Weight With Base: 56 lbs.
Still no tuners
Bob
Old 04-30-06, 08:04 PM   #3 (Link)
Loc: Lower Alabama
It's gonna be hard to beat $1500 on one of these. I have access to several of these and my cost on all of them are over $1500. This seems to be a really good deal.
Panasonic has a 37" Plasma that can be had for about $1160 but it only has an NTSC tuner and it's EDTV.
Old 05-01-06, 04:18 PM   #4 (Link)
Alias: Phil
Phil M's Avatar
User: #20
Phil M is offline
I don't know if the two are comparable but the Westinghouse LVM 42W2 had a great review in the May 'Home Theater'.
Old 07-31-06, 03:06 PM   #5 (Link)
Alias: Dougie
Loc: Pittsburgh, PA
User: #1263
Since: Jun 2006
Dougie085 is offline
Do all the scepter display devices have that blue light up logo on the front? If so thats the only thing that would keep me away from them. I know their computer LCD displays have them and it looks annoying.
Old 07-31-06, 04:43 PM   #6 (Link)
Tech'y Shackster
Alias: Bob
User: #25
Dougie085 wrote:
Do all the scepter display devices have that blue light up logo on the.
Nope. On the 37" at least there is only a single small led -- red when off, yellow when on. Hardly noticable
Bob
Old 07-31-06, 05:19 PM   #7 (Link)
Alias: Dougie
Loc: Pittsburgh, PA
User: #1263
Since: Jun 2006
Wouldnt be so bad then but honestly I'd rather have no led's at all.
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Mach 5 Audio
