Mits ws55819 convergence issues - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss Mits ws55819 convergence issues in the Home Theater | Audio and Video forum; Mits ws55819 convergence issues Hello all! I have a 55819 and as soon as the warranty ran out (figures) the convergence is off until ...
Old 11-06-06, 08:57 PM   #1 (Link)
New Member
Alias: mphoebus
Loc: Millsboro, DE
User: #3823
Since: Nov 2006
Mike Phoebus is offline
Hello all!
I have a 55819 and as soon as the warranty ran out (figures) the convergence is off until it warms up or i give it a little kick. Even when it goes back to a better picture I have to go into advanced convergence and reallign the blue and the red. Sometimes I get the "bowtie" as well. I'm told it may just be the circuit board that needs soldering and I can handle some soldering but not buying a new tv after only 5 years. Thanks for any help!
Old 11-07-06, 05:40 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Mits ws55819 convergence issues
You may need to simply resolder the connections on an output IC, or the chip could be intermittent internally. If the former is true and you keep running it without fixing it you will likely blow the IC anyway. These are routine repairs for a CRT based RPTV, just make sure that if you change the chip that you get an original SFS part, not a cheap knock-off. some servicers try to make big bucks on these repairs, but it should be no more than a 2 hour (possibly much less) job on site. Ask about rates before having a servicer come out if you don't DIY.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 01-19-07, 10:39 AM   #3 (Link)
Alias: Royce
Loc: Victorville, CA
User: #49
RollsRoyce is offline
Sadly, this is a common problem with the Mits CRT RPTVs and is also showing up in other makes as well. As Leonard said, it is a matter of resoldering the connections on the convergence ICs. You can pay someone to come out and resolder them, or if you're handy you can do it yourself. There's a lot of info about this on another forum, and you can even find an illustrated guide on how to do the repairs yourself if you go to the right Spot PM me if you can't find what I'm talking about!
---Royce---
"I never drink...wine..." Bela Lugosi, DRACULA, 1931
Old 01-20-07, 07:51 AM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
Let's put this in perspective. All CRT based RPTVs use convergence output ICs made by Sanyo. Various chips have varying reliability, and all of them run hot because of the nature of the circuits. They tend to develop solder cracks because of the thermal cycling. Some ICs just fail under the stress, and some fail due to the open circuits caused by the solder cracks. Some designs are worse than others about this. The Mitsubishi sets have actually been one of the more reliable sets in these regards, but all vendors have similar issues. In this series of Mitsubishi sets it is more common to have bad solder connections than bad ICs, but as with any sets, if you keep running it broken you can do more damage.
As for the advice on other forums, be very careful. I monitor them and try to keep people from making mistakes, but a lot of the info is out of context and incomplete. If someone wants to DIY one of these, I suggest you post questions here and I will advise you as to whether you are taking the right course of action BEFORE you do so. I do this for a living and many of the posts you see are from other DIYers that don't have all of the info or experience that they need to give such advice. Some ot what I have sen is just plain bad advice. Bottom line is, I am not telling you not to search the other sites, as there is a lot of help out there, just check it out with me before screwing something up or using the wrong parts. There are updates to many of the chips, additional things to check on some sets, and lots of vendors selling inferior parts.
-Joseph Joubert
Raise the bar.
Old 06-21-08, 05:23 PM   #5 (Link)
New Member
Alias: chris
Loc: rock hill sc usa
User: #22243
Since: Jun 2008
wooster is offline
Hello Leonard,
Can you give me some guideance on how to fix a convergence problem. Where is the circuit board that controls convergence and are cracks, if there are indeed cracks, noticable. Where can I find a repair manual. Any help would be greatly appreciated.
Chris
Old 06-21-08, 05:58 PM   #6 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
lcaillo is offline
The first 10 pages of this link are about as much guidance as I can give:
http://www.hometheatershack.com/foru...html#post43725
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
New Sony and Mits 1080 Projector comparison MACCA350 Home Theater Projectors 13 09-12-07 06:48 PM
Subwoofer wiring issues... aceinc DIY Subwoofers 13 10-30-06 07:57 PM
M Audio MobilePre Issues Nat Ward REW Forum 5 10-06-06 12:31 PM
Convergence Zone Roger Home Theater, Audio and Video News 0 09-01-06 12:30 AM
Server issues... Sonnie Forum Announcements | News 0 07-07-06 08:30 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
