Do I need a scaler? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Do I need a scaler?
Discuss Do I need a scaler? in the Home Theater | Audio and Video forum; Do I need a scaler? I have a Denon DVD-5900 that upconverts to 1080i (I think) and I am using it with a Sanyo PLV-Z5 ...
Old 02-14-07, 02:15 PM   #1 (Link)
Alias: Joe
Loc: CT
User: #6402
blownrx7 is offline
Do I need a scaler?
I have a Denon DVD-5900 that upconverts to 1080i (I think) and I am using it with a Sanyo PLV-Z5 projector. Is there any advantage to buying an outboard scaler? Which one? DVDO seems to be the most prevalent but are there others to consider?
Also, I purchased the Denon used and the previous owner installed an SDI output card. The only way to utilize it is with a sclaer that has SDI input. Again, is it worth the expense. Will I see significant picture improvement?
TIA
Old 02-14-07, 02:20 PM   #2 (Link)
Alias: Dougie
Loc: Pittsburgh, PA
User: #1263
Since: Jun 2006
Dougie085 is offline
Re: Do I need a scaler?
Do you have other sources that need to be scaled? The best reason to get a scaler is that the outboard scaler does a much better job of scaleing the image then the internal scaler on your projector or dvd player or other sources. The DVDO units are some of the better units and often are much better then onboard scalers.
Old 02-14-07, 02:33 PM   #3 (Link)
Alias: Joe
Loc: CT
User: #6402
blownrx7 is offline
Well, in that setup, there is only the vcr. Can that be scaled?
That and the DVD-5900 are the only two sources I'm using. I plan on getting an OTA HDTV tuner (when I find one but that's another story), but that would already be 1080i, right? Could it scale SD programming as well and is it worthwile to do so?
Oh, and what about standard catv (no cable box) too?
Sorry for so many questions but I am just beginning to step into the HD world and have a lot to learn
Old 02-14-07, 05:55 PM   #4 (Link)
Alias: brucek
User: #6
brucek is online now
I think a scaler is needed when you have a bunch of different sources with different resolutions and cable types that can be connected and switched by the scaler and then converted to a single common native mode of the projector using a single cable for the long run.
Yes, anything can be scaled, but it ain't magic. A VCR (480i NTSC) will not all of a sudden look great because it's scaled. There's no new information. The better the scaler, the better the result. There are lots of $10,000 scalers and then there are scalers much cheaper......
Old 02-15-07, 09:54 AM   #5 (Link)
Alias: Joe
Loc: CT
User: #6402
blownrx7 is offline
Well, I guess that's what I'm trying to figure out without taking the plunge first.
I indeed have different resolution sources. Will the vcr 480i actually look SIGNIFICANTLY better scaled up or just passed thru to the projector.
Also, will my Denon do any better through the SDI output to make it worth the expense of an SDI input on the scaler?
As far as DVDO, Given my inputs (DVD, VCR, SDTV (cable) and OTA HDTV, which one to get? The VP20, 30 or 50???
Lastly, has anyone used scalers and NOT been happy with the result?
TIA
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
