Optoma RD50 Lamp - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Optoma RD50 Lamp
Discuss Optoma RD50 Lamp in the Home Theater | Audio and Video forum; Optoma RD50 Lamp Just an FYI for any owners of this unit. I just changed one for a client and found that the ...
Old 05-28-06, 11:22 PM   #1 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Optoma RD50 Lamp
Just an FYI for any owners of this unit. I just changed one for a client and found that the lamp is the same Osram lamp that is used in the Mitsubishi WD52725. The Mits price is a lot cheaper. You would have to change the lamp and use the Optoma cage.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
