Would like to upgrade my display - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Discuss Would like to upgrade my display in the Home Theater | Audio and Video forum; Would like to upgrade my display Hello everybody! I have successfully upgraded my sound system for HT use, and it is now time to upgrade the ...
Old 09-13-07, 03:38 PM   #1 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Hello everybody!
I have successfully upgraded my sound system for HT use, and it is now time to upgrade the display.
The first step I made yesterday was buying a 720p/1080i capable samsung DVD player HD 870. Blue ray and HD DVD players are not for people living in Egypt at this moment....the movies are not available.
I also found yesterday at the store a Samsung 50" plasma 720p/1080i and a 46" Samsung LCD 720p/1080i for about the same price of 3300 $ approx. (yes I know it is that expensive here)....do not even think of a 1080p display
my room is 1800 cu ft... lighting is not bright during the day (no sun...), viewing distance is 10 ft approx.
The salesman told me that Plasma may be better for satellite standard broadcast (that I have here).
I like the colours, brightness and life of the LCD, but I like the bigger size of the plasma,...
I will be using the display most of the time for watching DVD movies, but rarely for PC application.
What are your opinions??
Thanks
NB: I did not take note of the models, but according to Samsung Web site, I believe the models are:
LN-T4642H and HP-T5054.
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 09-14-07, 01:38 PM   #2 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Re: Would like to upgrade my display
If this was two years ago I would have said go with the Plasma but todays LCD technology has come a long way and the contrast and blacks are in my opinion just as good as plasma. As far as color it could just be the setting of the display that they had on demo as plasma do have very good color/contrast as well . Plasma still has issues with burning out pixels and other issues where LCD usualy lasts longer. You could also look at getting a projector for the same or lower cost and paint on a screen this way you get a much larger screen size.
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2 HD DVD & Samsung BDP1400 BluRay players, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
Old 09-14-07, 04:08 PM   #3 (Link)
Loc: Lower Alabama
4" diagonal doesn't seem like it would be that much... I might would opt for an LCD as well.
I'm also in favor of investigating a projector, which should save you money and get you that bigger screen. You could go with a 60" screen size and have an amazing picture... or you could go on up to a larger size for that matter.
Sonnie
Old 09-14-07, 05:08 PM   #4 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
I do not have the option of painting a wall and use it as a screen. How much does a 96" screen cost? And would the image quality be as good (sharp, bright, colourful) as a plasma or LCD? wouldn't I be concerned about the resolution if I seat at a distance 10 ft from the screen (i.e what would be the most allowable screen size for that distance without compromizing quality/vieing pixels...).
I have been tofay again at the store and found that the LCD do not have a black issue, but they look quite "artificial" and make movies quite like a cartoon...
The plasma looked more natural, but the glare was even worse than a CRT (I think)...
Old 09-14-07, 05:14 PM   #5 (Link)
Loc: Lower Alabama
They vary drastically depending on manufacturer and type... good ones are probably $4-500 and up.
Check out some of the DIY options in our Screen forum. Those guys have got that stuff down to an art. You can buy a sheet of Wilson Art laminate, designer white for $75 or so and frame it out. Less than 100 bucks and equivalent to some $1000 screens. Mine is painted and looks great to me.
Do you have a spot for the pj?
Sonnie
Old 09-14-07, 05:22 PM   #6 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Sonnie wrote: View Post
No, never seriously thought of this option...Do you have a spot?
Old 09-14-07, 06:39 PM   #7 (Link)
Loc: Lower Alabama
Yeah... I have a pj mounted in my HT room. What I'm asking is if you have location to mount it. How deep is your room from front to back?
Sonnie
Old 09-14-07, 07:33 PM   #8 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
I see... I can mount it on the rear wall between the surround back speakers. The screen would be placed at about 11 to 12 ft away from the pj.
Old 09-14-07, 08:46 PM   #9 (Link)
Loc: Lower Alabama
Oh yeah... that would be perfect. This might be a viable option for you if pj's aren't too expensive in Egypt.
Sonnie
Old 09-14-07, 08:50 PM   #10 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
The advantage of pj is that they are relatively small and light...I can buy them from anywhere, I don't have to buy them from here.
Remember I bought dual RL-p18 from the US
Old 09-14-07, 09:03 PM   #11 (Link)
Loc: Lower Alabama
That's true... very true. Keep in mind too that for what you were going to spend on a display, you can buy a super nice pj. Or you could get a very good one for a lot less and use that other money towards something else. If you have light in the room (even ambient light), I would look at one with a good lumen output and get the right screen material, whether that be laminate, paint or a real screen... so that you don't have any viewing issues.
Check out projectorcentral.com for tons of reviews and all the specs you could ever imagine on just about any pj. If you find a few you like... post them in the pj forum here so we will all know what you are looking at.
Sonnie
Old 09-15-07, 09:19 AM   #12 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
blaser wrote: View Post
If you do start considering direct view again, don't trust the picture quality in a store unless they have everything in a good environment and have set it up properly (i.e. not bestbuy or similar). The contrast and brightness controls come from the factory turned all the way up which is why everything looked like a cartoon, and the glare would not be as noticeable in a room with dim lighting.
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Similar Threads
Considering the 2.35:1 anamorphic upgrade? rwood01 Home Theater Projectors 24 04-12-07 06:52 PM
What would an upgrade give me? PhilB35 SVSound 19 02-17-07 10:41 PM
display settings scott Home Theater Projectors 2 01-15-07 02:49 PM
upgrade jokers10 SoundSplinter 1 10-11-06 10:48 AM
Looking to upgrade Joshua Home Theater Equipment 3 05-18-06 11:16 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84
