Do LCD RPTV Bulbs Go Bad? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Discuss Do LCD RPTV Bulbs Go Bad? in the Home Theater | Audio and Video forum; Do LCD RPTV Bulbs Go Bad? So I have to change my LCD front projector bulb every 2000 hours. And I can noticeably tell that the ...
Old 10-29-07, 11:51 PM   #1 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
So I have to change my LCD front projector bulb every 2000 hours. And I can noticeably tell that the bulb quality is degrading every 500 hours in or so. But does the same hold true for the bulb in an LCD RPTV?
IIRC, Sears will replace the bulb if it blows up while under warranty, but there's no mention in the manual about having to order a new bulb, opening up the case, and replacing the bulb. Also, the picture quality doesn't seem to degrade the same way the front projector does. Either it degrades much more gradually so it's not as noticeable, or it just doesn't. Possibly because the light is not reflecting off the screen but passing through it.
Old 10-30-07, 04:31 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is online now
Re: Do LCD RPTV Bulbs Go Bad?
Front projectors typically have lamp life rated for about 2000 hours. RP systems are typically several times longer due to the lower power ratings on the lamps. There is a drop in output through the life of the lamp and more severe just before the lamp fails, but it would generally not be noticed at 25% of the life of the lamp. If you are seeing the picture degrade, it is likely due to needing some cleaning in the light path on a 3 chip system.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 10-30-07, 04:57 PM   #3 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Hm, well I don't think I want to be opening up my LCD RPTV, but it's probably been used about 4000 hours. Thanks for the info. It's good to know.
Old 10-30-07, 05:05 PM   #4 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
What brand of set do you use? The need for cleaning the optical path inside the light engine is the dirty little secret of three-chip systems.
-Joseph Joubert
Raise the bar.
Old 11-01-07, 04:43 PM   #5 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
I've got a Panasonic PT50LC13. 50" that I bought in early 2004.
Old 11-01-07, 08:49 PM   #6 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
Put full field red, green, and blue fields up and check each one for uniformity. If there are any abnormalities at all, you likely need the light path cleaned, especially if the blue has any problems.
-Joseph Joubert
Raise the bar.
Old 11-02-07, 09:15 PM   #7 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Meaning if there are some parts that look less or more green than others, to the naked eye looking dead on? I'll give it a shot.
Old 11-02-07, 09:37 PM   #8 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
Yes, do it for each color.
-Joseph Joubert
Raise the bar.
Old 11-04-07, 12:11 PM   #9 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Everything seems to look okay.
Old 11-04-07, 07:59 PM   #10 (Link)
Alias: Joe
Loc: Oregon Coast
AverageJoe's Avatar
User: #1314
Since: Jun 2006
AverageJoe is online now
Josuah wrote: View Post
I have the same set (well, I gave it to my son last week when we bought a new plasma), and I replaced the lamp late last year after about 4500 hrs. Panasonic had given 10,000 hrs as the estimated lamp life, but I felt pretty lucky since some people had replaced their lamp twice by then. Panasonic extended the lamp warranty to 18 months on that model, apparently due to so many early failures. They also offered a $1000 rebate toward a new set (of at least $1500) if you had three lamp-related failures within the warranty period.
Since you're at 4000 hours and out of warranty, you might consider buying a replacement lamp to have on hand. It's a single slide in module so they're easy to replace (but cost about $300 - Model# TY-LA1000).
Old 11-05-07, 06:04 PM   #11 (Link)
Alias: Josuah
Loc: San Jose, CA
User: #182
Josuah is offline
Eh, most likely if the lamp blows up we'll just take it to recycle or something.
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Similar Threads
CRT based RPTV Convergence Repairs lcaillo Manufacturers Service and Support 151 Today 08:51 PM
How to tell if a lamp is bad? loctones Home Theater Projectors 6 10-19-07 03:06 AM
Coolant Leaks in CRT RPTV lcaillo Manufacturers Service and Support 0 09-15-07 05:54 AM
Good 60+" RPTV for both HDTV and SDTV garycase2001 Home Theater Equipment 2 12-26-06 12:34 AM
FS: Pioneer Elite PRO-510HD 53" RPTV Brian Bunge Classifieds - Video Displays and Projectors 0 12-04-06 12:24 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
