| Video Displays and Processors 1080i vs. 1080pDiscuss 1080i vs. 1080p in the Home Theater | Audio and Video forum; 1080i vs. 1080p Hi there,
I'm a newbie (although I have downloaded REW some time ago)
Just looking at this amazing looking contraption ... |
| | #1 (Link) | |||
| 1080i vs. 1080p Hi there, I'm a newbie (although I have downloaded REW some time ago) Just looking at this amazing looking contraption for the attic, I immediately asked myself is there an issue with standing waves with speakers facing each other? I do plan to create a dedicated room for watching movies when I move to the country (soon) and the site is obviously the place to start. I have a question about HD. I want to buy a 42" tv and am confused about the difference between 1080i and 1080p. Which one should I be looking at and is there any good reference to TV specs on line? Kind regards Ed | |||
| | #2 (Link) | |||
| Re: 1080i vs. 1080p How far are you sitting away from the screen? Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #3 (Link) | |||
| Re: 1080i vs. 1080p Hello, I was VERRY confused last year before I bought my Pioneer Elite PRO-940HD plasma (1024X768). Many products have better specs, better resolution, better contrast, lower price, etc. So I came to a dealer and did many tests with diffrents products with the same HD and standard DVD source. After that day, I decided to pay less about specs and use my senses to make decision. That"s why I choose that Pioneer plasma over many products that have better specs and everytime a lower price ! Like blaster said, the listening distance is important. Do some of your tests at the same distance and with DVD and HD DVD or BluRay you know well. A nice plasma in 720P could give you a better image than a cheap LCD at 1080P. But if you are a gamer, then the resolution should be a concern. JP | |||
| | #4 (Link) | |||
| Re: 1080i vs. 1080p Check out Episode 14 for the skinny on 1080p. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #5 (Link) | |||
| Re: 1080i vs. 1080p I guess about 10 feet from the old tv at the moment. I've just had a look at eugovectors suggested link and find I have a lot to learn yet. I cant see myself sitting as close as the article suggests. Maybe I need a bigger screen. Thanks for your comment Ed | |||
| | #6 (Link) | |||
| Re: 1080i vs. 1080p According to what I read, you may propably not benefit from any higher resolution than 720p at that distance even with a 50" screen.... The human eyes have limits... Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #8 (Link) | |||
| Re: 1080i vs. 1080p The article does not take into consideration the viewing distance....I do not doubt 1080 is better that 720, but the question is "when will you benefit from a higher resolution" is another story. Keep in mind that resolution is neither the first nor the second but third most important parameter for image quality! Contrast ratio will be the first if I am not mistaken. Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #9 (Link) | |||
| Re: 1080i vs. 1080p If you're referring to the article one post up, it doesn't have to take seating distance into account. The article is showing that, with proper deinterlacing, there is no perceptual difference between 1080i and 1080p when using 24 fps source and a 1080p display (or any 60fps progressive display, for that matter). The conclusions hold true regardless of seating distance. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #10 (Link) | |||
| Re: 1080i vs. 1080p OK Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #11 (Link) | |||
| Re: 1080i vs. 1080p In my experience, the biggest difference between I and P is that I will in many cases give you judder. The uneven distribution of fields in the Interlaced technology. You'll notice this especially with slow panning shots in a movie. In the form of an image stutter which can be quite annoying. Especially the pioneers have a great way of dealing with this in advanced cinema mode, which will give you judder free pictures while being interlaced. I've got a toshiba hd-e1(1080 I) and a gen. 6 pioneer plasma. Great picture without judder. Dimitri ISF certified | |||
| | #12 (Link) | |||
| Re: 1080i vs. 1080p I hate to say it ..but when you get to be my age 720p 1080i 1080p all look pretty much the same. While I can really tell the difference between SD TV and HD TV 1080i or 1080p who can tell. Come on It's not much but it is a first post | |||
| | #13 (Link) | ||||
| Re: 1080i vs. 1080p Quote:
| | #14 (Link) | ||||
ISF certified | ||||
| | #15 (Link) | ||||
The only difference between interlaced and progressive video is how each frame is drawn. interlaced draws every other scan line starting with all the odd lines and then the even lines where progressive draws all of them at the same time. For sports and fast action movies progressive is a better choice but for movies with slow pans or little movement it makes little to no difference. Depending on the distance and size of your display 1080p may not be necessary. A 720p projector or display will work just as well in some cases. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 | ||||
| | #16 (Link) | ||||
Which causes telecine judder, because of the uneven distribution of fields. Dimitri ISF certified | ||||
| | #17 (Link) | |||
| Re: 1080i vs. 1080p Thanks, It was my understanding that there are many DVD players that do not do this correctly and fail the 2/3 pulldown test. Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i towers, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 | |||
| Thread Tools | |
Similar Threads | ||||
| Which 1080i DVD player of these three? | E-A-G-L-E-S | Home Theater Components | 9 | 09-20-07 03:25 PM |
| Upscaling 1080i or 1080p???? | salvasol | Home Theater Components | 7 | 04-30-07 05:18 PM |
| 720p, 1080i......... | Rodny Alvarez | Home Theater Projectors | 7 | 03-11-07 10:55 PM |
| 'Today' show going 1080i and we know what equipment they are using | HDBeat | Home Theater, Audio and Video News | 0 | 08-22-06 11:43 PM |
| 1080p screens | Alliancebloke | Projector Screens | DIY Screens | 7 | 07-31-06 03:02 PM |
