Component input - picture artifacts - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Discuss Component input - picture artifacts in the Home Theater | Audio and Video forum; Component input - picture artifacts Hi! When I use component to transfear a 720p or 576p signal to my tv or dlp-prj, I get a ...
Old 11-17-07, 05:11 PM   #1 (Link)
New Member
Alias: tommy_sn
User: #13344
Since: Nov 2007
tommy_sn is offline
Hi!
When I use component to transfear a 720p or 576p signal to my tv or dlp-prj, I get a "double" picture, but when I use 576i I don't get this. I have tried several sources and cables, with the same results on one lcd tv and one proj. Anyone who can help me why it is like this?
There is no problem when I use 720p over HDMI.
There are two pics of the problem added.
Thank you!
Old 11-17-07, 05:20 PM   #2 (Link)
Alias: Mike
User: #8033
Since: Apr 2007
Mike P. is online now
Re: Componenet input - picture artifacts
If you've already tried several sources and cables with the same result, I'd suspect an interference problem. Have you tried rerouting the component cable?
Old 11-17-07, 05:27 PM   #3 (Link)
New Member
Alias: tommy_sn
User: #13344
Since: Nov 2007
tommy_sn is offline
Yes, even tried to connect the X360directly to the tv with nothing else powerd on. Ialso had the same problem when I have the equipment in another house.
But why on just progressive signal? Does it need a better cable? Strange, since the X360 original-cable shouldwork without problems?
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Similar Threads
bad picture jimmyzowens Video Displays and Processors 6 11-21-07 05:37 AM
Mitusubishi WS55905 no picture from HDTV inputs tgwolf Video Displays and Processors 5 11-07-07 03:50 AM
Mitsubishi HD 1080 No Picture Breeze4u Manufacturers Service and Support 6 03-04-07 09:17 PM
Mach 5 Audio
