Mitsubishi 55905 Convergence - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Manufacturers Service and Support
Discuss Mitsubishi 55905 Convergence in the Home Theater | Audio and Video forum; Mitsubishi 55905 Convergence I have a Mitsubishi 55905 TV that is about 5 years old now and about four months ago the yellow ...
Old 11-24-07, 09:44 AM   #1 (Link)
New Member
Alias: Shizat
Loc: Orlando
User: #13717
Since: Nov 2007
Shizat is offline
I have a Mitsubishi 55905 TV that is about 5 years old now and about four months ago the yellow and red convergence has really shifted and I cannot fix it through the TV menu. I had a TV tech come out to take a look at it which was $100.00 right off the bat and he said that he had to order a part for it. Three months later after numerous phone calls he tells me they no longer make the part and he would have to change the whole chassis which would cost me $800. I would purchase a new HD TV for $400 more before doing that! I read other posts on here where at maximum a convergence fix should cost around 400 dollars. Anyone in the Orlando area that would recommend a good repair shop with technicians that return phone calls?
Old 11-25-07, 06:22 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Mitsubishi 55905 Convergence
It is unlikely that the part is unavailable. He probably tried to order the whole board, where repairing it would be the typical procedure. It is possible to need a board if you had a coolant leak, but most can be repaired. You should get a detailed estimate from the servicer who provided the estimate, including what part he is having trouble getting and how he diagnosed the problem. Go to the Mitsubishi site and find the local ASCs in your area and start with them when looking for a good servicer. Read the sticky threads in this forum for some god info.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Manufacturers Service and Support »
Similar Threads
Convergence Repair Help 95gp Manufacturers Service and Support 4 11-15-07 11:48 PM
Convergence Prob VS60609 Mitsubishi tjhol Manufacturers Service and Support 3 10-21-07 12:13 PM
Mitsubishi WS65907 Convergence Problems MIKEMC Manufacturers Service and Support 3 10-18-07 06:40 PM
ws-55809 convergence rustamust Manufacturers Service and Support 5 06-09-07 04:27 PM
Convergence Zone Roger Home Theater, Audio and Video News 0 09-01-06 12:30 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
