Mitsubishi WD-65731 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Mitsubishi WD-65731
Discuss Mitsubishi WD-65731 in the Home Theater | Audio and Video forum; Mitsubishi WD-65731 I have a Mitsubishi WD-65731 DLP Television. Yesterday I noticed that it looked a little bit dim. Today I noticed ...
Old 11-25-07, 07:14 PM   #1 (Link)
New Member
Alias: Sparky
User: #13761
Since: Nov 2007
Sparky321 is offline
Mitsubishi WD-65731
I have a Mitsubishi WD-65731 DLP Television. Yesterday I noticed that it looked a little bit dim. Today I noticed that is a lot dimmer than it was yesterday. The lamp indicator on the front of the unit is not on, when I start it up after it has been off for a while it takes 30-45 seconds to even begin to show a picture. I bought this television new in July so I know that it is still under warranty, although I'm not sure if it is a Best Buy warranty or a Mitsubishi warranty. I am just looking for a little input as to what the problem might be. Could the lamp be weak and not give an indicator light. If I leave it on for a while it seems to get a little brighter (could be my imagination). Does a lamp usually get dim that fast if it fails or does it take longer. Any input would be greatly appreciated. Sparky.
Old 11-26-07, 05:15 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is online now
Re: Mitsubishi WD-65731
Lamps do often dim when they are about to fail. Your set has a 1 year warranty with Mitsubishi and you should contact them to find a local servicer or have them send you a lamp directly.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 11-26-07, 06:31 PM   #3 (Link)
New Member
Alias: Sparky
User: #13761
Since: Nov 2007
I called Best Buy today and they contacted a local repair center who in turn said that it would be 7-10 days before they could come out and that they do not stock any parts. I called Mitsubishi and they said to expect a lamp in 2-3 days. Thanks for the reply.
Old 02-06-08, 12:45 PM   #4 (Link)
New Member
Alias: Fitbaboss
User: #16532
Since: Feb 2008
Fitbaboss is offline
I have had my 65731 DLP for one year and one month. At about 6 months the "Airflow" error kept coming up, eventually it would shut the t.v. off. I got it repaired via the one year warranty - the tech said it was a typical problem with these models, and he just went ahead and replaced all the "parts" associated with the issue (fans?).
Luckily, a day after the Superbowl, my lamp went dime and within a day it was dead....I estimate I got about 4,300 hours out of it...now I am shopping for a new lamp. Question is what's the difference between the lamp part number via the Mitsubishi website 915P049010 priced at $249 and the actual part number of 915p049a10 (is this the part for the casing and not the actual bulb)?
Thanks,
Old 02-06-08, 02:30 PM   #5 (Link)
Shack Service Mod
lcaillo's Avatar
User: #328
915P049A10 is not a valid Mits part number but you can get the same Osram lamp without the housing here:
http://www.intl-lighttech.com/store/item_GTL-OS-69490
Just wear gloves and don't get any oils from your hands on the lamp when changing it.
-Joseph Joubert
Raise the bar.
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Similar Threads
Mitsubishi HD1080 Edonoso Video Displays and Processors 3 11-17-07 04:07 PM
Mitsubishi lcaillo Manufacturer and Vendor Reference Information 0 05-12-07 10:56 PM
mitsubishi wt46809 billyd123 Video Displays and Processors 3 02-13-07 10:45 AM
Mitsubishi Meltdown alphaman Manufacturers Service and Support 1 02-05-07 10:34 PM
Mitsubishi Lebowski Video Displays and Processors 7 09-06-06 08:49 PM
Mach 5 Audio
