Aftermarket bulbs as good as OEM bulbs? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Discuss Aftermarket bulbs as good as OEM bulbs? in the Home Theater | Audio and Video forum; Aftermarket bulbs as good as OEM bulbs? Hi All, I need a new bulb for my JVC HDILA display. Trying to find an original JVC bulb is ...
Old 11-26-07, 08:56 AM   #1 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
Hi All,
I need a new bulb for my JVC HDILA display. Trying to find an original JVC bulb is tough but OEM equivalent bulbs are everywhere. Is there any reason not to go with the OEM equivalent bulbs?
Thanks,
Joe
Old 11-26-07, 05:12 PM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is online now
Re: Aftermarket bulbs as good as OEM bulbs?
So far, all of the replacement lamps have had a bad reputation. You can often find the OEM lamp from other vendors other than JVC, however. If you find the same lamp, you shold be fine. Just be sure that the markings and the OEM are identical.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 12-10-07, 09:25 PM   #3 (Link)
Bronze Supporter
Alias: Dale
Loc: Clovis, CA
htaddikt's Avatar
User: #8963
Since: May 2007
htaddikt is offline
I would like to add, be cautious of prices listed by some after-market retailers.
Always check your mfg. first for their price and use that for reference when shopping.
I found one retailer selling a specific Sony lamp for a lot more than what Sony charges.
Arcam AVR350, Dali Ikon 5.1, Velodyne DLS5000, Cambridge Audio 740C, Toshiba X-A1, Samsung BD-UP5000, Polk XM Tuner, Furman power conditioner
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Similar Threads
Do LCD RPTV Bulbs Go Bad? Josuah Video Displays and Processors 10 11-05-07 06:04 PM
Aftermarket power cord for SVS 20-39PC+? Huck SVSound 2 02-17-07 09:56 PM
Where are all the good jokes? Sonnie Chat Box 3 01-24-07 12:29 AM
Replacing oem driver with new, should I expect improvement? Deeje DIY Subwoofers 14 11-10-06 09:27 PM
good enough w/o BFD? rkruz REW Forum 5 10-09-06 08:01 AM
Mach 5 Audio
