Back 2.5" of DLP RPTV -- Not Supported ?? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Discuss Back 2.5" of DLP RPTV -- Not Supported ?? in the Home Theater | Audio and Video forum; Back 2.5" of DLP RPTV -- Not Supported ?? I found a stand that has compartments for my equipment, but it is only 15.5" deep. My t.v. is a ...
Old 11-28-07, 03:52 PM   #1 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
E-A-G-L-E-S is online now
I found a stand that has compartments for my equipment, but it is only 15.5" deep. My t.v. is a 65" dlp and it is 18" deep.
For those of you that have owned one you'll know that it is not a square back side.
It is very stable, but....
Is this a terrible idea? A nightmare waiting to happen?
Old 11-28-07, 04:59 PM   #2 (Link)
Loc: Lower Alabama
Re: Back 2.5" of DLP RPTV -- Not Supported ??
I don't think it would be a problem as long as it's stable like you say... and as long as it's balanced well.
Old 11-28-07, 06:02 PM   #3 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
Cool....because it works perfectly with my equipment requirements. It is very sturdy, I was just trying to rock/tip it and it would take a good jolt to knock it over.
It is perfectly level and the front edge is aligned with the front edge of the stand.
Old 11-28-07, 08:13 PM   #4 (Link)
Alias: Jim
Loc: Cincinnati
User: #10263
Since: Jul 2007
cynical2 is offline
Matt, you could always tether it to the wall, just to be sure.
Just take a decent size screw with a decent size head and a decent sized washer and drill it into a stud in the wall (about even with the top of the TV).
Then, take a piece if picture-hanging wire, loop it through an appropriate place on the back of the TV (some even have dedicated loops molded into the TV back...others you can loop it around the air vent slots), and then tie the cable around the screw head. The wire doesn't need to be completely taut, but should have very little slack.
It's a $2 way to insure that if someone ever does start to tip the set, it will be caught by the cable and stay on the video stand. So, you won't have to worry about it inadvertently tumbling to the floor.
Of course, you can also buy a kitbuy a kit , if you want to pay a lot more for the same functionality.
Jim
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Similar Threads
FS: 50" Samsung 1080P DLP & DVD upconvert/receiver with 5.1 surround system LG-HTI E-A-G-L-E-S Classifieds - Video Displays and Projectors 2 09-18-07 06:32 PM
Good 60+" RPTV for both HDTV and SDTV garycase2001 Home Theater Equipment 2 12-26-06 12:34 AM
FS: Pioneer Elite PRO-510HD 53" RPTV Brian Bunge Classifieds - Video Displays and Projectors 0 12-04-06 12:24 PM
The dreaded "little endian not supported" error Shez REW Forum 5 11-01-06 03:20 AM
REVIEW: 65" HP MD6580n DLP Microdisplay nobbie Video Displays and Processors 9 07-13-06 03:01 PM
Mach 5 Audio
