Colorimeter for both PC screen and projector screen? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Discuss Colorimeter for both PC screen and projector screen? in the Home Theater | Audio and Video forum; Colorimeter for both PC screen and projector screen? Does anyone know if theres a reasonably-priced colorimeter for both a PC screen and a projector screen? I've just bought ...
Old 12-07-07, 12:31 AM   #1 (Link)
Australian Contingent
Alias: John Simpson
Loc: Hobart, Tasmania
John Simpson's Avatar
User: #8852
Since: May 2007
John Simpson is offline
I've just bought a new Dell 27" LCD screen and it certainly needs calibrating -- I was just hoping to buy a tool that could also do my projector calibration down the track. All the PC ones seem to have suckers that stick them to your screen, which is no use for a projector screen.
Thanks!
View our home theatre project at the Wychwood website. Comments welcome!
Old 12-07-07, 05:57 AM   #2 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Re: Colorimeter for both PC screen and projector screen?
I use the I-one Beamer which is the I-one pro unit with a rather clumsy mount for reading from screens. I have not kept up with the most recent available meters. You might want to post the question on the CAlMAN forum. Those folks have tested most of the available meters for use with their software and would be the best qualified to give the pros and cons of the various products. I can tell you that the cheaper tri-stimulus colrimeters are likely to not be appropriate for all displays.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 12-07-07, 04:13 PM   #3 (Link)
Alias: John Simpson
User: #8852
Since: May 2007
Many thanks Leonard -- I've posted up on the Calman forums and will report back what they say.
Old 12-08-07, 11:46 PM   #4 (Link)
Alias: John Simpson
User: #8852
Since: May 2007
Got a reply back from the moderator on the CALman forums:
"The x-rite Display2 or Display2 LT seem to be the current favorite and will work well with both the display types you listed. The only difference between the D2 and D2 Lt is the software x-rite packages in but to us they are the same."
The x-rite looks ideal for LCD screens, but looking at their website I can't see how to use it for home theatre. I'll look into it some more...
Old 12-15-07, 11:56 AM   #5 (Link)
Alias: Bill
Loc: Inner Loop, Houston, TX
User: #1796
Bear5K is offline
All it takes is a suction cup, some superglue and a 1/4" hex nut.
CalMAN -- Home Theater Calibration Software
Old 02-15-08, 11:46 PM   #6 (Link)
Alias: John Simpson
User: #8852
Since: May 2007
I ended up buying the new Spyder 3 Elite, which can be used for monitors and front projection setups.
It's done a really good job of removing the blue cast from this screen, although I'm still trying to work out why its little blue light keeps flashing on and off while I work. I feel like I'm being watched...
Old 02-20-08, 02:23 AM   #7 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
John,
Do you have a link pls?
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 02-20-08, 03:59 PM   #8 (Link)
Alias: John Simpson
User: #8852
Since: May 2007
Yep, try this.
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Similar Threads
New Projector - need advice on screen gain srsmith Projector Screens | DIY Screens 8 08-20-07 09:26 PM
Painted screen vs laminate screen Harry Muscle Projector Screens | DIY Screens 5 07-05-07 05:04 PM
Motorized projector screen POP UP, not DROP DOWN EchoMike Projector Screens | DIY Screens 4 06-12-07 07:57 AM
What Screen to use?????? James Broccoli Projector Screens | DIY Screens 7 04-11-07 01:54 PM
Projector & Screen Recommendations Tommy Home Theater Projectors 37 07-20-06 01:46 AM
Mach 5 Audio
