| Video Displays and Processors HD-Ready QuestionDiscuss HD-Ready Question in the Home Theater | Audio and Video forum; HD-Ready Question *EDIT*
I just realized that this may better fit in the "General" section. I apologize if it is out of ... |
| | #1 (Link) | |||
| HD-Ready Question *EDIT* I just realized that this may better fit in the "General" section. I apologize if it is out of place. OK. I'm about to buy an Olevia 23" TV (I know it's small, but it's all I can afford ) The set says HD-Ready on Olevia's website although it's listed as HDTV on the sites it's sold at. From what I've read about HD-Ready, it seems that as long as I'm getting my HD channels from DirecTV (which will be the case) then HD-Ready is all I need. However, I'm wondering if I decide to buy an HD-DVD player down the road, will I also need to purchase a separate piece of equipment to use this with my TV? Any better explanations of what this HD-Ready means would help. Thanks.Thanks for any help anyone can give. -Ryan Last edited by powder21; 03-01-08 at 09:37 PM. Reason: Oops. | |||
| | #3 (Link) | |||
| Re: HD-Ready Question Also, what's your budget? Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #4 (Link) | |||
| Re: HD-Ready Question Can't say for sure if the HDTV you're looking at is HD ready or has a built in tuner. You are correct, if you have an HD ready TV and a DirectTV HD receiver you would be good to go. And no, if you pick up an HD DVD or Blu Ray player down the road you DO NOT need to purchase any other equipment. Mark | |||
| | #5 (Link) | |||
| Re: HD-Ready Question Thanks for the replies! Sorry, I forgot to post the model. It's the Olevia 323V. I'm pretty sure it doesn't have a built in tuner. Although, now I'm considering a 226V or 226T (I've started a new thread for THAT decision) My budget's only about $400 after tax (and shipping if needed), but I'm hoping I can squeeze another hundred outta my **** The 23 is just too small when viewing from 6 to 7 feet away.Thanks again for the help (would love to hear more) and pretty please check out my thread about the 226V vs 226T. -Ryan | |||
| | #6 (Link) | |||
| Re: HD-Ready Question If you're already worried about 23 being too small, it is. I'd save up until you can manage $600 for a 32". Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #9 (Link) | ||||
| Re: HD-Ready Question Quote:
A 32" simply won't fit where I want it to go...this is for a small bedroom. Another reason I don't want a 32" is because I am already going to have to listen to my stepdad complain about the fact that I bought a new TV (which he will do). Coming in with a 23" as compared to a 32" will result in less complaining. (My TV must be smaller than his TV )P.S. I'm most likely going to grab a 26" instead...there's another post about that decision here http://www.hometheatershack.com/foru...d-quality.html Last edited by powder21; 03-04-08 at 10:37 PM. | ||||
| | #10 (Link) | ||||
![]() ![]() Have fun with your hobby ![]() | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Am I HDTV ready? | hifidave | Home Theater Projectors | 1 | 10-24-07 08:01 AM |
| Getting ready for REW? | Warpdrv | REW Forum | 4 | 04-23-07 04:49 PM |
| Getting ready to put together my first... | Joeychgo | Home Theater System Recommendations | 8 | 08-15-06 01:06 PM |
| PLEASE READ: GETTING GRAPHS READY TO POST | Sonnie | REW Forum | 7 | 07-13-06 12:01 AM |
| Is 802.11n Ready? | Roger | Home Theater, Audio and Video News | 0 | 05-09-06 07:54 PM |
