Pioneer Plasma's - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Pioneer Plasma's
Discuss Pioneer Plasma's in the Home Theater | Audio and Video forum; Pioneer Plasma's The articles and reviews Ive been reading are pretty much putting the Pioneers as the best choice in purchasing a ...
Old 05-20-06, 01:47 AM   #1 (Link)
Alias: Tom
Tommy's Avatar
User: #51
Tommy is offline
Pioneer Plasma's
The articles and reviews Ive been reading are pretty much putting the Pioneers as the best choice in purchasing a plasma tv.
I've been running around to different stores this week to look at projectors AND plasma and it seems that none of the stores are stocking pioneer...
Old 05-20-06, 02:48 AM   #2 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Re: Pioneer Plasma's
Hmmm That's weird, maybe just out of stock, or supplier problems. Yes the Pioneers have been getting some excellent reviews and for good reason. They are a great buy if you have the $'s.
D.
Old 05-20-06, 03:02 PM   #3 (Link)
Alias: Tom
Tommy's Avatar
User: #51
Tommy is offline
D.
Yea it is weird, I've went to 1 to 3 stores each night for the last week. In the entire week I've only seen two places and they each only had one pioneer tv. All the other manufactures had a ton of different models to select from.
As I said I'm surprised specially when Im reading such good things about them.
Old 05-20-06, 11:28 PM   #4 (Link)
Alias: Pierre
Loc: NH
User: #475
pierrebnh is offline
You might also consider Panasonic.
Either way, beware of store demos as the picture is usually set to 'vivid' and severely saturated. Also take care to view the set from a distance approximating how far you'd be viewing it in your home to get the most accurate feel.
Old 05-23-06, 01:58 PM   #5 (Link)
Alias: HC
User: #229
highcurrent is offline
After 6 months of comparing, I went with Pioneer PRO1130 HD plasma just before the Superbowl. My choice was based on HD cable and DVD source material in light and dark conditions. Also, SD cable had to look good too (Fox news, CNN, etc) To my eyes, it won in every category. We got the 50" and are viewing it from 8' to 10'. The built-in scaler is the best, hands down. Panasonic was my second favorite for the black levels on dark scenes in a dark room and I would have been pretty happy with the Panny's too I think. I love the separate media receiver, front panel component inputs, PCMCIA mem card reader, and on and on.
I am absolutely thrilled with my selection. It has been 4 months of pure eyeball joy.
HC
Old 06-05-06, 12:04 PM   #6 (Link)
TVAuthority
Alias: Stephanie
Loc: My own corner of heaven
User: #884
Since: Jun 2006
Stephanie_tva is offline
The reason why Pioneers are in short supply right now is because they are in their transition phase from their older models (PDP-5060HD, PDP-4360 etc)
The newer models are due out this summer and will not have the separate media receiver but from the reviews it seems like Pioneer has maintained their exceptional quality.
Old 06-05-06, 06:30 PM   #7 (Link)
Alias: John
Loc: Plymouth,MA.
User: #205
xmas111 is offline
I purchased the PRO920 HD plasma last April(2005),and have no complaints at all!
I also think the separate media receiver was a great way to go.
You won't be disappointed with Pioneer!
Old 07-20-06, 12:15 PM   #8 (Link)
Alias: dimitri
Loc: netherlands
User: #944
Since: Jun 2006
dimmie is offline
I'll second that, the pioneers get a bad name when it comes to screen retention, but Im very happy with mine. And I've had no problems.
Dvd looks very good even through scart(rgb)
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
