Front Projection vs. LCD/PDP - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Discuss Front Projection vs. LCD/PDP in the Home Theater | Audio and Video forum; Front Projection vs. LCD/PDP I had been assuming to use a 1080 front projector for my media room, but this weekend saw a new ...
Old 02-17-08, 08:01 AM   #1 (Link)
New Member
Alias: interfx
User: #16508
Since: Feb 2008
interfx is offline
I had been assuming to use a 1080 front projector for my media room, but this weekend saw a new Sharp 65" LCD display. WOW!
Has anyone else seriously considered one of these ($4800) vs. buying a front projector, screen, and all of the mounts, wiring, etc. through your ceiling...
I know the front projector can go upto 100" based upon the size in my room, but 65" sure looks awesome for similar price...
What have others considered in this decision?
Old 02-19-08, 11:38 PM   #2 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
Re: Front Projection vs. LCD/PDP
I've seen two CRT front projectors in dedicated theater rooms, one Sanyo Z4 in a dedicated room, and calibrated a system with a Sanyo Z5. Honestly, none of them were able to match the 3d-ness and pop of a good flat panel display. I'm convinced you trade some PQ for size by going with a front projector, even with a proper room.
Unless you are going to be sitting >11' back, I'd get the 65" LCD.
Old 02-20-08, 02:18 AM   #3 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
The units you saw might not be the best or even close to the price indcated by OP. If we talk about $4800, I would also consider the new Epson UB projector with a DIY or a manufactured screen. PQ would propably not be as excellent as a Flat pannel, but should not be too far in an adequate viewing environment.
Big pictures also imply a WOW factor and FP has a more "professional" (is it?) looking dedicated HT.
BTW, I watched Ice Age in a showroom on the mits HC-5000, and I was stunned!! I felt it was a 100" "good" LCD pannel and that was with a bit of ambient light. The UB might have even a better picture and black level than the mits...
This is just my opinion, nothing expert...
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 02-20-08, 05:25 AM   #4 (Link)
Gold Supporter
Alias: Jean-Pierre
Loc: Beaumont, Quebec, CANADA
imbeaujp's Avatar
User: #12596
Since: Oct 2007
imbeaujp is offline
My oppinion is that the Plasma or LCD panel are technicaly better than projection.
Now the price are lower for under 70 inches and they could compete with the projector + screed price. But if you want 100 inches screen (assuming your room is big enouhg for that - That is THE question), projector is the best for price and easy installation (think about moving a 100 inches plasma in your basement...)
JP
Old 02-20-08, 10:42 AM   #5 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
If you are able to make the room dark enough then a projection system is a much better bang for buck but if you have light issues then a plasma/DLP or LCD direct view display would be the better choice.
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2,
2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD AX2 & Samsung BDP1400 DVD players, Sanyo Z2 projector
Two Channel system: Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub
Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR,
Sony KP-53HS30 rear projection HDTV, turntable PS-T20
Nintendo Wii
Old 02-21-08, 02:56 AM   #6 (Link)
Alias: Steve
User: #263
I'm not certain and I didn't bother to ask the respective owners, but I think CRT projectors are significantly more expensive than the majority of today's front projectors or flat pannels.
Old 02-21-08, 03:24 AM   #7 (Link)
Alias: Maikel
Loc: Arnhem, The Netherlands
User: #15347
Since: Jan 2008
maikeldepotter is offline
interfx wrote: View Post
IMO it all depends on for what purpose you want to optimize your HT.
For watching movies with a maximum of Theater experience you will defintely need some kind of front projection. Not only because it most closely resembles the Movie Theatre experience (beaming light onto a big white screen in a light controlled room). But also because really big LCD or plasma screens (if you are with more people sitting 2 to 4 times the screen height away from the screen) do either not exist, or cannot produce the picture quality you can achieve with front projection. And this does not necessarily has to be CRT front projection. For instance: I own a Panasonic PT-AE2000 that produces a much more impressive picture than the mentioned "biggest in the world" Panasonic plasma screen.
On the other hand, if you want to use your HT also under "plenty of ambient light conditions" then I would go for a good quality LCD or Plasma screen and accept that I will not have that wide cinema viewing angle unless I want to sit at arm lenght from the screen.
Last edited by maikeldepotter; 02-21-08 at 03:32 AM. Reason: improve on my english!
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Similar Threads
Need help with my Anamorphic Projection Setup footbllpro30 Anamorphic Projection 5 02-04-08 09:54 PM
Front Projection 1080p LCD's ACGREEN Video Displays and Processors 2 11-19-07 01:08 PM
Rear projection TV aceinc Video Displays and Processors 20 10-28-07 03:19 PM
Help from Sony for LCD rear projection with blue spots Joey Skinner Manufacturers Service and Support 4 08-03-07 02:08 PM
Cutoff on Sub and Front sonata31 REW Forum 3 09-27-06 12:10 PM
Mach 5 Audio
