Output to 720P or 1080i ? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater | Audio and Video > Video Displays and Processors
Discuss Output to 720P or 1080i ? in the Home Theater | Audio and Video forum; Output to 720P or 1080i ? Hello, I got the pioneer elite 940HD, 42" 1024x768 native resolution.This plasma has HDMI inputs and support 1080i as input ...
Old 01-23-08, 06:51 PM   #1 (Link)
Gold Supporter
Alias: Jean-Pierre
Loc: Beaumont, Quebec, CANADA
imbeaujp's Avatar
User: #12596
Since: Oct 2007
imbeaujp is offline
Hello,
I got the pioneer elite 940HD, 42" 1024x768 native resolution.This plasma has HDMI inputs and support 1080i as input signal as well as 720P. So my understanding is that it will downscale or upscale to it's native panel resolution 1024x768.
I listen HD DVD on a Toshiba HD-A2 that can output in 720P or 1080i and listen to HD TV with an Explorer 8300HD that also can output at 720P or 1080i.
My listening position is 10 feet from the display.
My question is, technicaly, what output should I select form my HD DVD and my cable box ? 720P (the pioneer will have to upconvert to 768P) or 1080i (the sources will then output in native HD format, no downsize, and the plasma will downscale then to 768) ???
Thanks !!!
JP
Old 01-23-08, 10:35 PM   #2 (Link)
Tech'y Shackster
Alias: Bob
Loc: Shueyville, Iowa
User: #25
bobgpsr is offline
Re: Output to 720P or 1080i ?
TV on cable or over the air is 1280x720p60 or 1920x1080i60.
Likely the best bet is to let the Pioneer display downscale from a 1080 input. But with the cable box you may want to try both. The cable 720p60 from ABC, ESPN & Fox may be better for sports.
Movies (film) are 1920x1080p24 on HDM media. Downscaling from 1920x1080i60 HD-A2 HD DVD player output to 1024x768 by your display might be the best bet.
Old 01-24-08, 02:18 AM   #3 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
Why don't you try the different setups and decide then? I think that's the safest/easiest way for you to find out what's best.
I had a similar issue with my DVD player and projector, try both 720P or 1080i and discovered which configuration gave me the best picture.
I agree with Bob: from what I have seen, downscaling is usually the best way to go (removing image information is easy). Upscaling is where your hardware start creating a part of the image and possibly making mistakes...
Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Sony PS3 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100"
Old 01-24-08, 09:21 AM   #4 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
I agree with whats been said above.
I think your best off using 1080i and let the display downconvert it. My Sanyo z2 projector looks better if I send it a 1080i signal but its only a 720p display.
Home theater:
Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Surrounds, SVS PB13 Ultra, AR center PSC25,
2 Audio control C131 EQ's, Toshiba HD XA2, Samsung BDP1400 BluRay, Pioneer LD, Sanyo Z2 projector
Two Channel system:
Yamaha RX-V995, Mission 764i's & A/D/S MS3u sub, Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer,
LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20, Nintendo Wii
My Webpage
Old 01-24-08, 09:34 AM   #5 (Link)
Gold Supporter
Alias: Jean-Pierre
imbeaujp's Avatar
User: #12596
Since: Oct 2007
imbeaujp is offline
My feeling is the same, the 1080i seems to look better, but I wanted to verify it "technically".
Thanks for all feedback to date.
Old 02-27-08, 04:22 AM   #6 (Link)
Alias: christos360
Loc: West Byfleet, Surrey, UK.
User: #17397
Since: Feb 2008
christos360 is offline
720p progresive is better and you dont want conversion issues.
Old 02-27-08, 05:12 AM   #7 (Link)
Shack Service Mod
Alias: Leonard Caillouet
Loc: Gainesville, FL, USA
lcaillo's Avatar
User: #328
lcaillo is offline
Scan conversion is always an issue. The question is which device does it better. There WILL be rescaling in the display, since it is 768. Generally, the display will have better processing than most cable boxes. It is usually best to set the box to pass through the native resolution of the signal and let the display deal with it. This avoids sloppy processing in the STB and multiple layers of processing. DVD players are more likely to have better processing, but you have the same potential issues. Overall, it is generally best to start with no conversion in the source and let the set de-interlace (if interlaced source) and resample (scale, convert) the image. Then start changing after you watch it a while on multiple sources and see what happens. You will likely see less artifacts and a better image with the STB on pass-through (if it has it enabled). The DVD player is a bigger question, as it is likely far better than the cable STB.
"It is better to debate a question without settling it than to settle a question without debating it."
-Joseph Joubert
Raise the bar.
Old 02-27-08, 05:13 AM   #8 (Link)
Alias: christos360
User: #17397
Since: Feb 2008
Thanks I thought it was better to run 720p sorry
Old 02-27-08, 09:22 AM   #9 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
christos360 wrote: View Post
Not nessisaraly true as 720p is still only 720 lines of resolution progressive is simply that the lines are all drawn from top to bottom all at once where interlaced is every other line starting with the odd lines and then the even. Progressive is good for fast motion video like sports but for movies with more slow pans and stationary shots 1080i will still give better results as there are far more lines of resolution being seen. If your display supports it, it is usually the better way to go for most movies.
Home theater:
Two Channel system:
My Webpage
Old 02-27-08, 05:15 PM   #10 (Link)
Gold Supporter
Alias: Jean-Pierre
imbeaujp's Avatar
User: #12596
Since: Oct 2007
imbeaujp is offline
And I think that the native resolution is not 720 but 768 so if the signal recieved is 720, your display have to Upconvert, no ?
Old 02-27-08, 06:38 PM   #11 (Link)
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
tonyvdb is offline
Yes, so it wold be best to try both settings and see what looks best.
Home theater:
Two Channel system:
My Webpage
« Home Theater Shack > Home Theater | Audio and Video > Video Displays and Processors »
Similar Threads
1080i vs. 1080p Ed Jackson Video Displays and Processors 16 12-03-07 02:38 PM
Question about 720p/1080i setting DanC High Definition | HD DVD | Blu-ray 6 11-12-07 10:33 PM
Box Sub Output vs. IB Sub Output NickTF DIY Subwoofers - Infinite Baffle 15 10-18-07 09:25 PM
Upscaling 1080i or 1080p???? salvasol Home Theater Components 7 04-30-07 05:18 PM
720p, 1080i......... Rodny Alvarez Home Theater Projectors 7 03-11-07 10:55 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
