| Welcome | Member Introduction hooking up buttkickersDiscuss hooking up buttkickers in the General Shack Area forum; hooking up buttkickers Hi everybody,
JUst bought a buttkicker and I have question on hooking this up. I own a Bose system 28 ... |
Views: 484 - Replies: 6
| hooking up buttkickers Hi everybody, JUst bought a buttkicker and I have question on hooking this up. I own a Bose system 28 series 1. If I get a y splitter and go from the speaker rca jacks on the bose and then to the buttkicker amp which speaker should I go from. Back speakers or front speakers on the Bose. Which is better? I have not received my buttkicker amp yet. Due in Tuesday but I can hardly wait. Also should I get two y splitters and go from both back speakers or bith front speakers and then combine them for the butt kicker amplifier or can I get it from just one speaker on my bose. I have also a harmony 890 and it is great. I have a blue light that uses z wave technology so when I watch a movie the blue light in back of the tv lights up the wall to create a mood that is great. THe harmony 890 can control the blue lights. I bought the wireless butkicker link but I will run the speaker wire under the rug until I know I have the butkicker set right. Then I will try the wireless link which I can get the harmony to automatcally turn the amp on when I watch a movie. Thanks | ||||
| | #2 | ||||
| Welcome to Home Theater Shack! Howdy booboo759 and welcome to the Shack! I am sure you will find all you need, but if we can help, just holler... ![]() Sonnie ![]() ![]() | ||||
| | #3 | ||||
| Re: hooking up buttkickers Hey booboo! Welcome to the Shack! ![]() | ||||
| | #4 | ||||
| Re: hooking up buttkickers Welcome to the Shack! Glad you found us! | ||||
| | #6 | ||||
| Re: hooking up buttkickers First of all ... Welcome ![]() ... I don't know if this will work, but let's try it.I read the owner manual online and I see that there's no "Sub output" just L,C,R,SL, and SR; (usually on Sub out is where you connect the buttkicker amp to be able to get the .1 signal from movies" ... I assume that your Bose send that signal to all speakers L,C,R,SL,SR .. or the "module" is also the subwoofer (I'm not familiar with Bose).Try using a "Y" like you posted from L and R; but if you do it the buttkicker amp will get the full range signal ... I think you can control it with the crossover on the amp. If this doesn't work ... I'm sorry but you'll need to get a new AVR with a sub out; or if you want to try to get help from the manufacturer ![]() Don't be surprised if someone tells you that Bose is not good ... reality is that for the price, you can get something better (like in this case with a sub out). I have two buttkicker LFE in my HT ... I used the sub out on the AVR to connect it ![]() | ||||
| | #7 | ||||
| Re: hooking up buttkickers Great to have you here. Have fun, Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| Bookmarks |
| Tags |
| buttkicker installation |
| Thread Tools | |
