Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > General Shack Area > Welcome | Member Introduction
Hi from Boston!
Discuss Hi from Boston! in the General Shack Area forum; Hi from Boston! I just heard about this forum over on audiokarma, and although I admit that I joined up in order to ...
Views: 270 - Replies: 7
Old 07-29-08, 11:54 AM   #1
New Member
Alias: judge
Loc: Boston
User: #23674
Since: Jul 2008
  judgeschreber is offline
Hi from Boston!
I just heard about this forum over on audiokarma, and although I admit that I joined up in order to download the REW software, I plan to hang out for a while to see what's going on here.
Although I only use 2-channel audio, I use my main rig for both audio and a/v, and I'm very keen on getting the best performance out of my system for a/v use.
My first task here: try to figure out why my system sounds so bad when the audio is run through my Sony 34HS420, then into my stereo, with the volume control function on the TV turned on. When volume control through the TV is bypassed, all sounds great. I suspect it has something to do with BBE processing, but I haven't yet figured out how to disable this while retaining the ability to adjust the volume through the TV remote. . . .
Old 07-29-08, 12:03 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Hi from Boston!
Hi judge, Welcome to the Shack!
Enjoy your stay here with us.
I am thinking that it is the BBE as well, there is usually a way to turn it off but only if you can get access to the service menu but I wouldn't play in there unless you are sure what you are adjusting as you can really mess up your display if not done properly.
If you ask this question in this thread I am sure someone will help you.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 07-29-08, 12:03 PM   #3
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Welcome to Home Theater Shack!
Howdy judgeschreber and welcome to the Shack!
I am sure you will find all you need, but if we can help, just holler...
Sonnie
Old 07-29-08, 03:25 PM   #4
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Re: Hi from Boston!
Hello judge, glad to have you here. Have fun, Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 07-29-08, 04:47 PM   #5
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is offline
Re: Hi from Boston!
Welcome to the Shack judge!
Gain Readings
Spectro Readings - not up to date but will be soon
Old 07-29-08, 09:22 PM   #6
New Member
Alias: judge
Loc: Boston
User: #23674
Since: Jul 2008
Re: Hi from Boston!
Thanks for the warm welcomes!
And yes, that service mode can be a minefield, but I'm learning my way around it slowly but surely. . .
Old 07-30-08, 10:52 PM   #7
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
Re: Hi from Boston!
Welcome to the Shack.
Mark
Old 07-30-08, 11:57 PM   #8
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is offline
Re: Hi from Boston!
Hello and welcome!
We're all in this together!
Members DIY Subwoofer Database
« Home Theater Shack > General Shack Area > Welcome | Member Introduction »
boston!
