| Welcome | Member Introduction Im new tooDiscuss Im new too in the General Shack Area forum; Im new too HI MY NAME IS STEVE,AND I STARTED A SMALL HOME THEATER WITH A DENNON 2807,DEFINITIVE POWER CUBE 10" SUB AND ... |
Views: 280 - Replies: 8
| Im new too HI MY NAME IS STEVE,AND I STARTED A SMALL HOME THEATER WITH A DENNON 2807,DEFINITIVE POWER CUBE 10" SUB AND SMALL CENTER,2 SPEAKERCRAFT 8" 125W Pivoting In-Ceiling Speaker FOR REARS AND 2 OLD CERWIN VEGAS 3-WAY 12"WOOFER (REPLACING THEM WITH DEFINITIVE BP 7004'S)FOR FLOORSTANDING,PS3 FOR BLUE RAY AND MY DISPLAY 32" OLEVIA WICH NEEDS TO BE UPGRADED TOO.I HAVE THE PS3 SET TO LINEAR PCM AND MY DENNON SAYS MULTI CHANNEL DOES THIS MEAN IM GETTING THE BEST AUDIO OUT OF THE DVDS AND BD?THANKS IN ADVANCE | ||||
| | #2 | ||||
| Welcome to Home Theater Shack! Howdy sevans28 and welcome to the Shack! We hope you find yourself hanging with us regularly... ![]() Sonnie ![]() ![]() | ||||
| | #3 | ||||
| Re: Im new too Hi Steve and welcome to the Shack! | ||||
| | #4 | |||||
| Re: Im new too Quote:
Welcome to the shack. If you're using HDMI with your Denon, that should do it as long as your AVR supports DolbyTrueHD and the like. If your Denon does not have support for Dolby TrueHD and the like, you can set it to PCM, but you still need HDMI. Also, and there's no easy way to say this, you might want to do something about your "Caps Lock" key ![]() Once again, welcome. Marshall Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||||
| | #5 | ||||
| Re: Im new too Welcome Steve! ![]() | ||||
| | #8 | ||||
| Re: Im new too Welcome from one newbie to another. Although I'm not sure what model Denon AVR you have, it sounds similar to the way I run my Onkyo 605, which also reads "multichannel" when playing Blu Rays. When the PS3 is set to PCM, it will do the decoding and then send it on to your receiver. In an effort not to embarrass myself, I'll avoid spewing details and jargon I'm not completely familiar with and just say, I believe you are properly set up. (Assuming you're connected via HDMI.) In other words, I agree with what Marshall said a few posts ago. ![]() | ||||
| | #9 | ||||
| Re: Im new too Welcome, Steve, Have fun, Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
