| Welcome | Member Introduction the new blu ray playersDiscuss the new blu ray players in the General Shack Area forum; the new blu ray players dear all
not to seem like an idiot but i get very confused by bitstream vs PCM. which blu ray ... |
Views: 278 - Replies: 6
| the new blu ray players dear all not to seem like an idiot but i get very confused by bitstream vs PCM. which blu ray players decode what and then if they are passed to my processor are they passed as the true signal or converted. I have a Samsung 1500 blu ray player feeding an NAD T175 processor( which at the moment does not decode the new codecs) and is then sent to a 500 series Phase Tech Darts system and a JVC RS 1x. Does anyone know what happens to the DD plus and Dolby True HD that is decoded in the Samsung and is then sent to the NAD as the NAD reads it out as Neo Cinema 6? thanks | ||||
| | #2 | ||||
| Welcome to Home Theater Shack! | ||||
| | #3 | ||||
| Re: the new blu ray players Hi Doc, Welcome to the Shack! You should post your question here as you will get more responses to it. The quick responce is that keeping you Samsung set to output Bitstream is the setting you want. Dolby Digital+ is the same as Dolby Digital but has less compression its alot like DTS. If your not connected using HDMI to your receiver that is the best you will get and if your receiver does not suport DTS master audio or True HD you just need to make sure when you play a Blu Ray DVD to not select either of those options in the audio setup menu. These usually default to Dolby Digital Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #4 | ||||
| Re: the new blu ray players Welcome to the Shack! Glad to have you with us! | ||||
| | #5 | ||||
| Re: the new blu ray players Hello Doc and welcome! ![]() | ||||
| | #6 | ||||
| Re: the new blu ray players Welcome, Doc. I've been in this business for thirty years and I frequently run into things I don't understand. There is plenty of knowkedge to be shared here and I am sure you will find lots of help. Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for. Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information. | ||||
