Go Back   Home Theater Shack > General Shack Area > Welcome | Member Introduction
Register
hello from Allentown, PA
Discuss hello from Allentown, PA in the General Shack Area forum; hello from Allentown, PA I am mrbill5. I just got started in home theatre. I won't be getting hot and heavy into it since ...
Old 08-16-06, 05:51 AM   #1 (Link)
New Member
Alias: mrbill5
Loc: SE PA
User: #2037
Since: Aug 2006
mrbill5 is offline
I am mrbill5. I just got started in home theatre. I won't be getting hot and heavy into it since my finances says no. I am using a HK 5.1 receiver , ACS kit main speakers.
Purchased my first subwoofer in the spring, AV123 Rocket. The ACS front speakers are run full range and are flat down to about 40hz. THe subwoofer is crossed over around 45hz. AND of course now that I have heard a glimpse of low frequencies I want to build a subwoofer that goes down strong to at least 20hz.
THe central speaker is a Radius thinline speaker, the surrounds are small KEFs. THe TV is a 5 year old 27" JVC CRT which works fine. We won't buy a flat panel until we have to, probably when digital broadcasts are the norm. THe living room is our theatre room. Sony DVD player.
We watch mostly over the air TV and use Netflix for movie rentals.
So my plans are to build a subwoofer this winter, no bigger than 4 ft3 due to room limitiations and put the Rocket up for adoption.
One thing that the Rocket subwoofer told me is that I have a real nasty 50 Hz peak in my room. THe Rocket has an automatic built-in single band paramentric equilizer that gets rid of this peak. I have since then downloaded frequency sine waves from 10 to 200 Hz. I have also purchased a Radio Shack analog sound meter. I haven't done any measurements yet.
I will be using the knowledge of the group to direct me in my system tweeking. I will do a frequency room sweep and determine how bad it is othar than the 50Hz peak. I plan to get some sort of equilization, possibly a parametric equilizer. I wish that I did not have to get "pro" equipment and the balanced-unbalanced cable kludging that is needed to get things connected. Right now RCA connectors are fine for me.
Old 08-16-06, 08:43 AM   #2 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Re: hello from Allentown, PA
Welcome to the Shack!
Definately check out the Room EQ Software here. It will greatly reduce the time needed to do proper sweep testing on your system.
Old 08-16-06, 10:38 AM   #3 (Link)
Loc: Lower Alabama
Sonnie is offline
Howdy mrbill5 and welcome to the Shack!
You'll probably find that the 50hz peak is just the beginning of response issues, unless you are one of the fortunate ones. The BFD can certainly fix that for you at a reasonable price though. You can always use RCA to 1/4" adapters or pick up some RCA to 1/4" cables. I had bluejeancables.com build some for me.
You mentioned space limitations... have you thought about IB?
Old 08-16-06, 02:30 PM   #4 (Link)
New Member
Alias: mrbill5
Loc: SE PA
User: #2037
Since: Aug 2006
mrbill5 is offline
I am going to keep things simple.
1 subwoofer, possibly a Rhytmik (sp) 12" or 15" design.
Equalization will be via either digital or analog equilizer. Equilization on the subwoofer only either a Rane or DBX or?
Old 08-16-06, 02:34 PM   #5 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
For the subwoofer: Behringer DSP 1124P Feedback Destroyer, it is also a great multi-filter parametric EQ for only $99.
Old 08-18-06, 04:18 PM   #6 (Link)
Alias: Pyro
Loc: Midwest USA
Pyro's Avatar
User: #1860
Since: Aug 2006
Pyro is offline
Well we're living here in Allentown
And they're closing all the factories down
Out in Bethlehem they're killing time
Filling out forms
Standing in line
Well our fathers fought the Second World War
Spent their weekends on the Jersey Shore
Met our mothers in the USO
Asked them to dance
Danced with them slow
And we're living here in Allentown
Oh, sorry! Hello MrBill, welcome to the Shack!!!
It's Better To Burn Out, Then Fade Away!
« Home Theater Shack > General Shack Area > Welcome | Member Introduction »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
