Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > General Shack Area > Welcome | Member Introduction
How to figure out which wires are front and rear
Discuss How to figure out which wires are front and rear in the General Shack Area forum; How to figure out which wires are front and rear I just moved to a new place which is surround sound wired, however none of the wires are marked whether ...
Views: 274 - Replies: 9
Old 01-01-09, 11:18 PM   #1
New Member
Alias: Salim
User: #31249
Since: Jan 2009
  sunderji is offline
I just moved to a new place which is surround sound wired, however none of the wires are marked whether they are FL or FR or RL or RR. I would appreciate if you know a way I can figure it out, I am a non-techie so detailed way to figure out would be much appreciated.
Also Front Right means facing the TV or Receiver it is on the right or does it mean right of the TV or receiver (meaning standing juxtaposed )
Thanks much !
Salim
Old 01-01-09, 11:22 PM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: How to figure out which wires are front and rear
Hook up one at a time and listen, or use a battery to "bump" the speakers.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 01-01-09, 11:23 PM   #3
New Member
Alias: Salim
User: #31249
Since: Jan 2009
  sunderji is offline
what does use a battery to bump the speaker mean ?
Old 01-01-09, 11:31 PM   #4
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Well, connecting on the speaker end should be obvious, assuming the wires are run to specific Right, Center, Left, Surround locations. Hook up your speakers, being sure to pay attention to polarity.
Then, on the other end, take a battery and connect one wire to the + and the other to the -. At that point, you should be able to hear a slight pop or buzz when you connect and disconnect the battery.
...or, you can just hook it up to your receivers channels, run a test tone, and note what channels are firing up (if your Right Surround fires up when it should be your Left Front, switch it).
Old 01-01-09, 11:39 PM   #5
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Welcome to Home Theater Shack!
Howdy there sunderji and welcome to the Shack!
I am sure you will find all you need, but if we can help, just holler...
Sonnie
Old 01-02-09, 12:48 AM   #6
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
Hello Salim, Welcome to the Shack.
Mark
Old 01-02-09, 06:35 AM   #7
Alias: mech
mechman's Avatar
Loc: Empire Township, MN
User: #6446
  mechman is offline
Welcome Salim!
mech
Old 01-02-09, 06:51 AM   #8
Alias: Mike
User: #8033
Since: Apr 2007
  Mike P. is online now
Welcome to the Shack!
We're all in this together!
Members DIY Subwoofer Database
Old 01-02-09, 09:43 AM   #9
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Welcome Salim. If you have an ohm meter, you can twist one set of wires' ends together, then find the set of wires on the other end with the low ohm reading. Then untwist the identified wires and repeat for each set of wires until you have marked them all. Have fun, Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 01-02-09, 02:35 PM   #10
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Welcome to the forum ...
Enjoy your stay .
« Home Theater Shack > General Shack Area > Welcome | Member Introduction »
figure, front, rear, wires
