| Welcome | Member Introduction Hi thereDiscuss Hi there in the General Shack Area forum; Hi there Hi everyone,
i was looking for rta software and ran across REW and seen the forum so here i am. ... |
Views: 179 - Replies: 8
| Hi there Hi everyone, i was looking for rta software and ran across REW and seen the forum so here i am. so i will play with the software using a audyssey mic from one of the denon recievers i install and then get a good mic and phantom supply for use with the usb input (if it works). well i am off to download and give it a try. latter Savage Last edited by SAVAGE; 02-26-09 at 07:51 PM.. Reason: messed up | ||||
| | #2 | ||||
| Welcome to Home Theater Shack! | ||||
| | #3 | ||||
| Re: Hi there Welcome to the forum ... ![]() Good luck with REW...don't forget to share your measurement graphs ![]() | ||||
| | #4 | ||||
| Re: Hi there Welcome to the Shack! Andrew | ||||
| | #5 | ||||
| Re: Hi there Hello and welcome to the Shack! | ||||
| | #6 | ||||
| Re: Hi there Welcome Savage! Stick around, you'll like it here. ![]() | ||||
| | #8 | ||||
| Re: Hi there Welcome SAVAGE. I use the Audyssey from my Denon with great results. Have fun. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
