Learning about home and pro audio - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > General Shack Area > Welcome | Member Introduction
Discuss Learning about home and pro audio in the General Shack Area forum; Learning about home and pro audio Hello, all! I came in from a link at Head-Fi headphone board after seeing a dicussion on sub eq-ing. The ...
Old 09-12-06, 09:05 PM   #1 (Link)
oyo
Alias: oyo
oyo's Avatar
User: #2558
Since: Sep 2006
oyo is offline
Hello, all!
The Room EQ Wizard caught my attention, since I have been working on the eq by ear in a large room with a tri-amped PA system with a set of Rane RPM88's as speaker controllers. I thought I would see how well it would translate over from home theater audio.
I'm sure it will help at home on a 5.1 system too, what with my miss-matched mishmash of 70's 80's and 90's components.
Good, clear punchy sound is my goal, no matter whether it is pro or home audio and no matter what the age of the components...
Old 09-12-06, 09:36 PM   #2 (Link)
Loc: Lower Alabama
Re: Learning about home and pro audio
Hi oyo and welcome to the Shack!
I'm sure you'll like REW and glad you found your way over...
Old 09-13-06, 09:56 PM   #3 (Link)
oyo
Alias: oyo
oyo's Avatar
User: #2558
Since: Sep 2006
oyo is offline
Thanks for making REW available from the forum. The program appears to be the ideal set-up tool for both home theater and pro audio uses. It has many advanced features that go beyond your average real time analyzer.
Any plans to include TEF analysis? REW is already awesome, adding the ability to "see" reflected, delayed sound would rock!
I have been lurking and learning today- great info here. I can't wait to test the room response, at home, work and church.
Home- My Boston Acoustics sub shakes the house OK on movies, but sounds unnatural on CD playback.
Work- a bizarre permanent installation sets up a bizarre standing wave problem that probably can't be EQ'd away.
Church- A real high tech system that should sound much better than it does. I've tuned it about as well as I can without measurement tools, (other than my ears). Thanks to REW and my trusty RatShack SPL meter I can now see where the problems are...
Hac in hora So at this hour
sine mora without delay
cordum pulsum tangite; pluck the vibrating strings
Old 09-15-06, 01:49 AM   #4 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Hey Oyo
welcome to the shack, pro audio has been an interest of mine as well
Old 09-17-06, 10:21 PM   #5 (Link)
Alias: Bob
Loc: Pittsburgh, PA
khellandros66's Avatar
User: #962
Since: Jun 2006
khellandros66 is offline
I wish I had stuff worthy of Rane EQ's owell...
Welcome to the Shack...
~Bob
Old 09-18-06, 02:47 PM   #6 (Link)
oyo
Alias: oyo
oyo's Avatar
User: #2558
Since: Sep 2006
oyo is offline
khellandros66 wrote: View Post
~Bob
The good stuff is not at my house- I'd have a tough time to justify even a used BFD there.
Real Life Family Center, ( http://www.reallifefamilycenter.com/) the church I go, to just bought a newly remodeled building from another congregation that felt the call to move downtown.
The other church had top-of-the-line gear sold to them, including an overpriced (for the application) high end HT surround processor and 3 home audio amps, as well as 9 QSC commercial amps. They put in FOUR Rane RPM 88's that do compression, limiting, distribution, automixing, crossovers, and other tasks. The problem is that the contractor sold the previous tenants a lot of gear and (mostly) installed it, then went out of business without setting any of it up well.
When I visited one of their services before they moved, they had a lovely "wall of mud" kind of vibe in their sound. Upon inspection after we moved in the subs ( were crossed over at 120 Hz while the mains were crossed at 80. This, combined with room resonance modes made for low intelligibility and low end feedback/ring modes in the room.
I was able to tame a lot of that by just resetting the crossover to 90Hz on the subs and mains, and have since been working with the delays to time align the system, and to EQ the room by ear.
REW should be a big help, but I'm thinking I should also buy one of the Behringer measurement mics, rather than using my RS digital SPL meter's mic. From lurking a bit, I've seen that the SPL meter mics are OK for setting subs but not so accurate for whole system. I'd like to run a sweep or eight to see what the real response is for each part of the system.
Any advice, or should I take this to another thread at this point?
Thanks.
Hac in hora, sine mora, cordum pulsum tangite;
So at this hour, without delay, pluck the vibrating strings;
Old 09-23-06, 11:18 PM   #7 (Link)
Shack City Slicker
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
Welcome aboard!
If you haven't already started your own thread it wouldn't hurt to go ahead and do so. Your question will get the attention it deserves in the BFD/REW forum
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
« Home Theater Shack > General Shack Area > Welcome | Member Introduction »
Similar Threads
Pro amps for HT Ayreonaut Home Theater Components 64 12-07-06 03:55 PM
Audio Control Maestro M2 pre/pro bricor Classifieds - Audio Equipment 1 08-19-06 10:31 PM
Audio Pro Sub Focus Ilkka Subwoofer Tests 3 07-17-06 02:34 PM
What's your favorite home theater or audio/video magazine? Sonnie General Discussion 23 06-09-06 06:29 AM
Pro Audio Amps JCD Home Theater Components 22 05-17-06 05:58 PM
Mach 5 Audio
