| Welcome | Member Introduction with some delay ...Discuss with some delay ... in the General Shack Area forum; with some delay ... Just noticed that I never said Hi to you guys, even though I already subscribed early 2007.
Being a long ... |
Views: 209 - Replies: 10
| with some delay ... Just noticed that I never said Hi to you guys, even though I already subscribed early 2007. ![]() Being a long time two channel aficionado time has come to start a budget HT setup, based around a set of 5 or 7 DIY speakers (CT230). As for the electronics, I'm clueless, too many choises and it seems that each component has its own processors, so you end up buying three and using only one. Also I'm baffeld by all the acronyms you use out here, will take some time to learn. But first things first, get the acoustics right ... My 2-channel set up in a dedicated room: Nottingham Analogue Hyperspace (first generation) with Grado statement master Technics SL-1100 with Denon 103-R on the original arm or an Empire EDR.9 on a Hadcock Toshiba SR-370 with a Denon 103-R (Shibata re-tip) Bow ZZ-eight CD player Graaf WFB Two pre amp Graaf GM20 power amp Zingali Overture 2S loudspeakers Ingo | ||||
| | #2 | ||||
| Re: with some delay ... Hi there, enjoy the forums! | ||||
| | #3 | ||||
| Re: with some delay ... Hello Ingo! ![]() | ||||
| | #4 | ||||
| Re: with some delay ... Well... it's about time... ![]() Welcome to the Shack! | ||||
| | #5 | ||||
| Re: with some delay ... Hello, Ingo, whatever questions you have about HT and the many acronyms within, we will be glad to answer. You are correct in often the DVD Player, Blu Ray Player, and AV Receiver all offer the same processing. Often, the AV Receiver is what you will want handling your surround decoding. Mostly because having the AVR handle it allows for Room Correction, and Bass Management to be handled in the easiest way. Cheers, JJ | ||||
| | #6 | ||||
| Re: with some delay ... Belated Welcome. Have fun. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #7 | ||||
| Re: with some delay ... Welcome to the site, Ingo! Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx | ||||
| | #8 | ||||
| Re: with some delay ... @Sonnie, thanks again for "rebooting" my account. @JJ, found the glossary, that will help. How does one add a word / get a word added? For example ETC & TEF are not in there. @All, thanks for the welcome. | ||||
| | #9 | ||||
| Re: with some delay ... Hello, Seed, at least in the Martin Logan Speakers vernacular, ETC stands for Energy Transfer Coupler. It is in regards to their spikes for decoupling the speakers from the floor. Now, forgive the presumption, ETC is also written to mean excetera. Which means and so forth. TEF could be in reference to a company which makes computer based acoustic analysis tools. Otherwise, I am not sure what that means. Cheers, JJ | ||||
