| Welcome | Member Introduction Hello From Ontario, CanadaDiscuss Hello From Ontario, Canada in the General Shack Area forum; Hello From Ontario, Canada Hi All,
i am new here and am very pleased so far with all the posts i have read to ... |
Views: 227 - Replies: 15
| Hello From Ontario, Canada Hi All, i am new here and am very pleased so far with all the posts i have read to date. I am also in the market for new equipment. Other than the big bix stores, anyone have recommendations where to begin to look for Projectors, screens, ect? Thanks | ||||
| | #2 | ||||
| Re: Hello From Ontario, Canada Hi Mobsterx, Welcome aboard the Shack! Are you looking for speakers and a receiver as well? Enjoy your stay with us. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | ||||
| Re: Hello From Ontario, Canada Welcome to the Shack mobsterX! ![]() | ||||
| | #4 | ||||
| Re: Hello From Ontario, Canada Hello, Welcome to HomeTheaterShack. As far as projectors go, my absolute personal favorites are Sony's SXRD projectors. I use the Sony KDS-55A300 which is an RPTV which I absolutely love. The only thing I would replace it with is a Pioneer Kuro Panel. Sony's VPL-HW15 is what I would go with: http://www.projectorcentral.com/sony...w15_review.htm If you have a higher budget, Sony's upper models are simply stunning as well. However the HW-15 retails for 3 thousand Dollars which is in the sweet spot for high quality projectors. Cheers, JJ | ||||
| | #5 | ||||
| Re: Hello From Ontario, Canada Welcome to the Shack! | ||||
| | #6 | ||||
| Re: Hello From Ontario, Canada Welcome to the Shack, mobster! For screens, Carada is a good company that my brother got his screen from. I personally had a Da-Lite screen which was a great buy, as well. Firehawk can be found in local Magnolia stores, but their pricing seems to be quite a bit higher, at least in retail stores. I've always been a fan of Sony's projectors, so my recommendation echoes with JJ said. Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx | ||||
| | #8 | ||||
| Re: Hello From Ontario, Canada Welcome. Have fun. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #9 | ||||
| Re: Hello From Ontario, Canada I like to look around the internets for cheap electronics. Amazon and TigerDirect have tonnes of audio video equipment and they're usually the cheapest because they're so big, nobody can really compete with them. | ||||
| | #11 | ||||
| Re: Hello From Ontario, Canada Thanks all, well i dont really know what my budget just yet really is, but nothing outrageous. So far i was considering the Infocus X10,the Optima HD20, or the Viewsonic Pro8100. I have not been a real big fan of Viewsonic, since my fathers Viewsonic LCD panel screen looked so bad. As for the screen, i am looking for Motorized. My room will not have any windows, so ambient lighting will not be a problem. No idea on reciever yet, but thinking either Pioneer or Yamaha. I do want a multi-zone reciever because i plan on putting audio into another room. I am open to speaker suggestions, i have always liked Paradigm or Energy. Thanks guys. Joe from Ontario | ||||
| | #13 | ||||
| Re: Hello From Ontario, Canada Hello, Joe, when using a Front Projector, you really can discern the difference between 720p and 1080p. The same cannot be said of small Panel Displays. It is great that ambient light is not an issue. I am a huge fan of Paradigm Speakers and think they would be an excellent solution. What are your room dimensions? Cheers, JJ | ||||
| | #14 | ||||
| Re: Hello From Ontario, Canada It depends on the size of the screen, a 720p projector on a 100" screen will look just as good as a 1080p projector as long as your sitting at least 10' back from the screen. the closer you sit the more noticeable it will be the farther back you sit (more than 10') and the difference is not worth the upgrade cost. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #16 | ||||
| Re: Hello From Ontario, Canada Then the cost difference between a 720p and a 1080p projector is not really worth it in my opinion. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
