Hi from New Brunswick - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > General Shack Area > Welcome | Member Introduction
Discuss Hi from New Brunswick in the General Shack Area forum; Hi from New Brunswick I'm in the process of building a recording studio (11'X13'X8') which is small and I'm hoping it will sound good ...
Old 10-27-06, 08:21 AM   #1 (Link)
Alias: Richard
Loc: New Brunswick
User: #3449
Since: Oct 2006
Richard Daigle is offline
I'm in the process of building a recording studio (11'X13'X8') which is small and I'm hoping it will sound good enough to do professional recordings, I'm planning to record some of my own songs.
My next step is to find a sound pressure level meter (SPL) so I can test the lower frequencies.
I'm wondering if there is a way for me to test lower frequencies without buying an SPL meter, since I have high quality microphones here, but they are not C-weighted. I also have software that simulates a spectrum analyser.
In my corners, I built panel absorbers to absorb frequencies from 70 to 110 Hz and then I put 4" triangles of fibrex insulation in front of the panels, from the floor to the ceiling. The triangles are 2'X2'X 2'10".
BUT I'm wondering why the panel absorbers behind the fibrex insulation didn't improve the sound????
Old 10-27-06, 09:27 AM   #2 (Link)
Loc: Lower Alabama
Re: Hi from New Brunswick
Hi Richard and welcome to the Shack!
You might be able to use your mic instead of an SPL meter, your mic should be better if it's flat. I'd post this question in the BFD | REW Forum.
I'd post the acoustics question in Acoustics... this way the proper folks will see your questions. You should be able to get some very good help.
« Home Theater Shack > General Shack Area > Welcome | Member Introduction »
Mach 5 Audio
