Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > General Shack Area > Welcome | Member Introduction
Good day from Wakefield - UK
Discuss Good day from Wakefield - UK in the General Shack Area forum; Good day from Wakefield - UK Hi all, I found the site through avforums.co.uk - whilst searching about home cinema set-up. I am planning on getting ...
Views: 639 - Replies: 6
Old 12-02-06, 11:26 AM   #1
Alias: gary
Loc: UK
User: #4578
Since: Dec 2006
  needmorstuff is offline
Hi all,
I found the site through avforums.co.uk - whilst searching about home cinema set-up. I am planning on getting a ratshack spm and using my laptop that has mic in and headphone out to optimize my system.
Cya.
Old 12-02-06, 11:47 AM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Good day from Wakefield - UK
The Radio Shack SPL meter has a line-out jack that needs to plug into a line level line-in jack on a soundcard.
Unfortunately, a mic in jack on a laptop doesn't work properly. It has a very poor frequency response, is quite noisy and often supplies a DC voltage on the line for microphones.
Most people that use laptops purchase an inexpensive external USB soundcard for this duty. They come with a proper line-in and line-out jack.
See the REW Help files for the software (free) required to do frequency response checks.
Old 12-02-06, 01:00 PM   #3
Alias: gary
Loc: UK
User: #4578
Since: Dec 2006
thanks - I just read a few posts on the forum and came up with as much.. shame. I will get the soundcard. Could you just confirm that it will help me get my home cinema optimized? I do not have a BFD (don't even know what one is )
Old 12-02-06, 01:29 PM   #4
Alias: brucek
User: #6
  brucek is offline
One of the main purposes of the REW software is to set up the filters in a BFD. The BFD is a Behringer Feedback Destroyer and is used as a parametric equalizer in line with a subwoofer to adjust its frequency response. Subwoofers tend to have very poor response (in a home setting) with large peaks that hurt the overall sound of your HT. The BFD simply tailors the subwoofers output with the use of parametric filters. There is a guide here.
Without a BFD, then REW can help by showing you the best positioning of your subwoofer in a room to perhaps even out the response. Without a BFD, your results may be limited though.
Old 12-02-06, 02:01 PM   #5
Alias: gary
Loc: UK
User: #4578
Since: Dec 2006
brucek wrote: View Post
thanks for that - maybe I need one of those then
Old 12-02-06, 02:41 PM   #6
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Hi Gary and welcome to the Shack!
I'm sure you'll find all the help you'll need to get your sub-bass optimized.
Old 12-03-06, 01:42 PM   #7
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
Hello Gary,... Welcome aboard.
Mark
« Home Theater Shack > General Shack Area > Welcome | Member Introduction »
