blekenbleu - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > General Shack Area > Welcome | Member Introduction
blekenbleu
Discuss blekenbleu in the General Shack Area forum; blekenbleu Greeting - Long-time audio hobbyist (built tube equipment in the 50s from military surplus) with allergies and decreasing tolerance of ...
Old 01-04-07, 12:00 PM   #1 (Link)
Alias: blekenbleu
Loc: Lexington, KY
User: #5329
Since: Jan 2007
blekenbleu is offline
blekenbleu
Greeting -
with allergies and decreasing tolerance of carpets, drapes, acoustic treatments.
Read about REW on AVS and decided it would be too much bother;
ordered a Denon 5805, discovered it was marginal for smoothing bass,
followed BFD issues to these fora.
Old 01-04-07, 08:09 PM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: blekenbleu
Hello blekenbleu and welcome to the Shack!
The Audyssey MultiEQ doesn't do so well with sub-bass... or at least it didn't for me. BFD all the way... REW is pretty easy after you start messin' with it, so you might give it a second look. Actually the next version should be ready soon and it may be a little easier to work with.
Sonnie
Old 01-05-07, 07:41 PM   #3 (Link)
Alias: blekenbleu
Loc: Lexington, KY
User: #5329
Since: Jan 2007
Re: blekenbleu
Yes, it seems my timing is pretty good; another user (Gizmo) is having
success with REW and Creative's Extigy (which I also have), and with the
BFD 1.4 EPROM becoming available , I may not have to search around for an older
used one. I expect to be running many calibration attempts, since the room
has little damping and I will need to try many placements for my pair of subs.
« Home Theater Shack > General Shack Area > Welcome | Member Introduction »
Mach 5 Audio
