Freezing in Minnesota... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > General Shack Area > Welcome | Member Introduction
Discuss Freezing in Minnesota... in the General Shack Area forum; Freezing in Minnesota... New member to this forum.... After sending some simple plotting of my sub's room response to SVS, Tom at SVS ...
Old 01-28-07, 08:51 AM   #1 (Link)
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
chas is offline
After sending some simple plotting of my sub's room response to SVS, Tom at SVS suggested I check out this forum for some info on the BFD. I am working on some DIY bass traps and panels, but he seemed to think the Behringer might be beneficial.
I've been dabbling in HT for a couple years and have a simple set-up that I enjoy toying with. SVS sub, speakers from Ascend Acoustics, Yamaha receiver with a couple of Outlaw monoblocks and an InFocus 4805.
Once I'm able to post links I have the Excel file with my plots and graph on the web so perhaps someone might be kind enough to take a peek and steer me in the right direction!
Chuck
Old 01-28-07, 09:50 AM   #2 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Re: Freezing in Minnesota...
Looking forward to seeing the plots. If you have bass peaks the BFD will help greatly and should help reduce the amount of bass traps you will need. If you have dips you'll have to rely on bass traps, furniture etc... to help.
Old 01-28-07, 10:07 AM   #3 (Link)
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
chas is offline
Well I may have to redo my graph as I was using RS meter correction factors that differ quite a bit from the ones provided on this site (I believe I got mine from the SVS site). Are the ones posted here the most accurate available?
Old 01-28-07, 11:26 AM   #4 (Link)
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
drdoan is offline
Chas, Welcome. I too, was born and raised in Minn. (Richfield). I had the BFD and used the Room EQ wizaed to set it. It does a great job, especially if you hook up midi to the BFD. It sets the BFD automatically. Have fun. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
Denon AVR-2807 Receiver w/AudysseyXT
LG DVD Recorder w/HDMI
Direct TV DVR HD
Optoma H31 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 01-28-07, 02:50 PM   #5 (Link)
Loc: Lower Alabama
Sonnie is offline
Hello Chuck and welcome to the Shack!
You have definitely been sent to the right place and we look forward to having you around and being a part of the Shack...
Sonnie
Old 01-29-07, 07:51 AM   #6 (Link)
Alias: chas
Loc: Minnesota
User: #6091
Since: Jan 2007
chas is offline
Thanks for the welcome. I'm still a little confused about the Radio Shack SPL meter correction factors posted here on this site. The are very different from those posted elsewhere...the large difference in the 16hz figure really throughs my graph off...
« Home Theater Shack > General Shack Area > Welcome | Member Introduction »
Mach 5 Audio
