Greetings from new DEQ2496 owner - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > General Shack Area > Welcome | Member Introduction
Discuss Greetings from new DEQ2496 owner in the General Shack Area forum; Greetings from new DEQ2496 owner I found this site searching Google for setup tips for my Behringer DEQ2496 that I recently purchased to assist with ...
Old 06-07-06, 12:47 AM   #1 (Link)
Alias: nathanso
User: #964
Since: Jun 2006
nathanso is offline
I found this site searching Google for setup tips for my Behringer DEQ2496 that I recently purchased to assist with room correction for my 2-channel system (see bio). I'm hoping the Room EQ Wizard will soon support the DEQ2496, though I'm going to try it anyway as a stand-alone measurement tool.
Old 06-07-06, 01:10 AM   #2 (Link)
Loc: Lower Alabama
Re: Greetings from new DEQ2496 owner
Hey nathanso and welcome to the Shack!
Glad you stumbled across us. I think it's somewhat in the plans to eventually have the REW setup for the DEQ2496, but JohnM has to purchase a unit so that he can do this.
As you suggest though... REW will still work well with it, you just won't be able to auto load the filters. You can still have REW help you determine the needed filters and then manually load them, which is what a lot of people do with the 1124.... if they don't have a MIDI interface. I actually did it manually for about 5 years.
Old 06-07-06, 11:10 AM   #3 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Yeah, I think you came to the right place!
I hope you stick around even after you get your system setup.
JCD
Old 06-08-06, 09:43 PM   #4 (Link)
Alias: Bob
Loc: Pittsburgh, PA
khellandros66's Avatar
User: #962
Since: Jun 2006
khellandros66 is offline
Welcome to HTS and if need any advice we are all here to help out.
~Bob
Old 11-01-06, 02:02 AM   #5 (Link)
Alias: nathanso
User: #964
Since: Jun 2006
nathanso is offline
Is there a way to use the DEQ2496 to create separate L and R auto-EQ curves and then combine the two results into one GEQ L+R curve?
Old 11-01-06, 03:53 PM   #6 (Link)
Loc: Lower Alabama
I would ask that question in the BFD | REW Forum.
« Home Theater Shack > General Shack Area > Welcome | Member Introduction »
Mach 5 Audio
