SACD Sampling Rate confusion - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 05-02-11, 09:57 PM Thread Starter
Seth D.
So was listening to my Living Stereo SACD of Rachmaninoff Concerto #3 tonight and comparing my new(er) Sony BDP-S370 to my Yamaha DVD-C961 and was surprised to see the Yamaha sampling @ 88.2 kHz Sony playing back @ 176 kHz. Any idea why my Yamaha wouldn't sample at the same rate as the Sony?
Strangely enough, the Yamaha sounds more articulate to my ears. My receiver is a Denon AVR-1909 and am using HDMI on both playback units.
Thoughts & insights appreciated!
ndurantz is offline
post #2 of 11 Old 05-03-11, 06:26 AM
robbo266317's Avatar
bigbadbill
Re: SACD Sampling Rate confusion
A sampling rate of 88.2 (or 2 x 88.2 = 176) theoretically shouldn't have much difference on the sound.
Personally I think any difference between the two would be in the analog filtering stage.
The only real way to test this is to do a double blind test, where you score the sound without knowing which unit is playing. Or simply play the discs on the unit you prefer........
Cheers,
Bill
Silence is golden but duct tape is silver.
DIY completed:
robbo266317 is offline
post #3 of 11 Old 05-03-11, 08:26 AM
Kal
ndurantz wrote: View Post
Designer's choice. All the Oppos, for example, will output only 88.2 from SACD while the Yamaha BD-A1000 will do 176.4 as will the Sonys.
I doubt it is the sampling rate. The Yahamas tend to have a brighter, more detailed treble, generically.
Kal Rubinson
__________________________________
"Music in the Round"
Senior Contributing Editor, Stereophile
Kal Rubinson is offline
post #4 of 11 Old 05-04-11, 10:28 PM Thread Starter
Seth D.
Just to make sure this nub understands, there is an actually a difference between 88.2 and 176.4 sampling rates, but when all is said and done, we are splitting hairs as the audible difference is minimal.
ndurantz is offline
post #5 of 11 Old 05-04-11, 10:38 PM Thread Starter
Seth D.
That makes sense, as what I was hearing in the upper range.
ndurantz is offline
post #6 of 11 Old 08-23-11, 11:43 PM
RTS100x5's Avatar
RTS100x5
My MARANTZ DV6001 has an upsampling option, maybe the SONY too ??
RTS100x5 is offline
post #7 of 11 Old 08-24-11, 08:29 AM
Kal
RTS100x5 wrote: View Post
AFAIK, no consumer product up-samples SACD.
Kal Rubinson
post #8 of 11 Old 08-24-11, 02:43 PM
RTS100x5's Avatar
RTS100x5
true yes, I was a bit misleading, I forgot he was listening to SACD. As far as playback of my SACD and DVD-A I always use the analog 7.1 output vs HDMI. Is there any technical difference ?? My reason for this is my analog stage has been modded w BURSON discreet opamps and wouldnt be part of the HDMI signal path... Also the recorded sampling rate of 96khz / 24bit is preserved and not resampled by a DVD player or otherwise..that I know of .......
RTS100x5 is offline
post #9 of 11 Old 08-24-11, 03:28 PM
Kal
OK. I prefer using the HDMI but it depends on what you connect it to.
The recorded sampling rate of SACD is not 96khz / 24bit but, rather, "The SACD sampling rate is 2.8224 MHz and the resolution is one bit." Arithmetic tells us that this is somewhat more than 24bit/176.4kHz.
Kal Rubinson
post #10 of 11 Old 08-27-11, 09:39 AM Thread Starter
Seth D.
I didn't realize that (never have been the best at math). So those 24/96 downloads from places like HD Tracks are lower fidelity than most SACD? Sorry if I am off in my understanding.
ndurantz is offline
confusion , rate , sacd , sampling
