Onkyo TSX805 Audessy Eq - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 7 Old 02-27-14, 05:17 PM Thread Starter
john
My question is this in my Onkyo 805 when I run the Audessy Eq setup and it's completed.
I should be able to go into the Eq. And see the settings it made correct? Because all the Eq. Settings are at 0 after running the setup. Was there something I needed to turn on?
Thanks John
dieselpower1966 is offline
post #2 of 7 Old 02-27-14, 05:37 PM
tonyvdb's Avatar
Tony
Re: Onkyo TSX805 Audessy Eq
No, you can not view the settings that Audyssey sets for EQ if you go into settings to view it you are in manual mode and all the settings that were made in the auto setup are reset.
The only adjustments you can change are the speaker levels and distance plus the crossover. You do not want to touch the distance settings and do not adjust the crossovers to a lower setting than what was set during the auto routine.
Home theater:
Living room system:
tonyvdb is offline
post #3 of 7 Old 02-27-14, 05:43 PM Thread Starter
john
Tonyvdb
Thanks for the quick reply. I did change the distance on 2 speakers. The auto setting was off by 12" on the left surround and 6" on the center. Do I need to run Audessy again?
post #4 of 7 Old 02-27-14, 05:54 PM
tonyvdb's Avatar
Tony
The distance settings are not actual distance, Audyessey uses that to calculate proper phase and delay within the room response.
When you ran it did you put the mic on a trypod and read at least 6 positions even if it meant moving the mic just a foot in each direction.
Home theater:
Living room system:
tonyvdb is offline
post #5 of 7 Old 02-27-14, 05:57 PM Thread Starter
john
Yes, I did the 8 position setup
post #6 of 7 Old 02-27-14, 06:00 PM
tonyvdb's Avatar
Tony
Well see how it sounds and go from there. You will most likely want to raise the sub level a bit but start with listening to a few sections of movies
Home theater:
Living room system:
tonyvdb is offline
post #7 of 7 Old 02-27-14, 06:10 PM Thread Starter
john
Thanks. I'll do run some select tracks. Possibly run the EQ. Again and post results
audessy , eq , onkyo , tsx805
