Audyssey Graphs - Please post your results! - Page 12 - Home Theater Forum and Systems - HomeTheaterShack.com
post #111 of 122 Old 11-09-13, 11:49 PM
vann_d's Avatar
vann_d
Re: Audyssey Graphs - Please post your results!
I realize this thread is pretty much dead but my latest subwoofer measurements are below. Taken with REW and a UMIK-1 calibrated from CSL. MultiEQ XT seems to do a pretty good job. You can also see the effects of dynamic EQ at this SPL level. I have noticed that Audyssey applies gains and cuts and will also adjust the overall sub level. It also seems to increase THD significantly (as measured by REW). Maybe all eq does, not sure. Sounds great nonetheless!
Audyssey Graphs - Please post your results!-sub-response-w-wo-audyssey-20131102.png
vann_d is offline
post #112 of 122 Old 11-09-13, 11:55 PM
Blaser's Avatar
Ahmed
Send a message via MSN to Blaser
vann_d wrote: View Post
Amazing.
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Blaser is offline
post #113 of 122 Old 12-07-13, 01:55 AM
New Member
Not sure if this is the place to post this. Im very new to the whole REW thing, just got my UMIK1 mic and set it up on a Macbook. I measured at the main listening position, but have no idea how good (read bad) the graph is that i ended up with. This is after running Audyssey on my Marantz SR6008. I have an SVS 12NSD in my living room, so there are no room treatments etc, its just a regular rectangular shaped room.
Any input/advice/comments would be greatly appreciated. Oh yeah this is my first post
Ocean is offline
post #114 of 122 Old 02-18-14, 03:03 AM
omega6666's Avatar
Tom
Still working on the 41 Hz suckout, but subs placement possibilities are limited, so it's phase, distance, volume settings and direction only :/. I like the sound though, which is kind of what matters. DynEQ is on, -10 dB reference level offset. Target settings with hard knee house curve and 1,5 dB/octave rolloff @ 1 kHzAudyssey Graphs - Please post your results!-snap-15.jpg
omega6666 is offline
post #115 of 122 Old 02-20-14, 10:51 PM
bigdogaxis's Avatar
Paul
Let me know how solve it. I have a 60Hz hole unless I open one of the double doors which moves the hole to 50Hz. Go figure
Waiting for Jerry Jones to fire himself.
bigdogaxis is offline
post #116 of 122 Old 03-08-14, 07:21 PM
Banned!
Here's our current graph.
Two Rythmik FV15HPs attached to a Denon AVR4520CI using XT32/SubEQ HT room correction software. Each subwoofer is equipped with a PEQ that allows each sub to separately EQ a particular frequency or bandwidth. One subwoofer is placed directly behind the MLP and one is placed on the opposite wall across from the MLP.
BeeMan458 is offline
post #117 of 122 Old 03-08-14, 07:32 PM
Banned!
bigdogaxis wrote: View Post
Usually it's caused by a two reflections (primary and secondary) running into each other. And usually, the offending wall is the one directly behind the MLP.
Where is the door located that changes your null from 60Hz to 50Hz and what happens when both doors are opened?
post #118 of 122 Old 03-09-14, 10:24 AM
bigdogaxis's Avatar
Paul
BeeMan458 wrote: View Post
Usually it's caused by a two reflections (primary and secondary) running into each other. And usually, the offending wall is the one directly behind the MLP. Where is the door located that changes your null from 60Hz to 50Hz and what happens when both doors are opened?
Offending wall is 10 ft behind MLP (see photos). Both doors open creates large nulls at 60Hz & 80Hz. I am holding off posting REW plots until I measure the Audyssey results.
post #119 of 122 Old 03-09-14, 12:24 PM
Banned!
It looks like the receding wall angles on the double door area are what's causing your room fits. From your image, it's looks like you have an angle on the wall of the equipment rack and then at the door.
What happens when you place a Depth i below the equipment rack?
post #120 of 122 Old 03-09-14, 01:58 PM
Full range with subs obviously quite hot. I assume this looks pretty bad? Also 0-200 to show subs.
Bear123 is offline
audyssey , graphs , post , results
